Select "engine diag", then "DTC's", then select every line that has "HO2S" AND "sensor 2" (for example P0137). Then just remove "x" from "SES enable" and select "3 no error reported".
Thanx Pekka
Much appreciated, I am from Finland myself as well, orginally from a little village outside Vasa!
Don't forget to DISABLE the "cat overtemp protection" system--should be a one-line entry--enable/disable---this system will richen up the mixture to cool the cats down--when in PE mode it will make the AFR way rich---You may get false triggers with the cats off and deleted--
