Corvette Forum
Go Back   Corvette Forum > C5 Corvettes, 1997 - 2004 > C5 Scan & Tune
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
C5 Scan & Tune
Corvette Onboard Diagnostics, Service Advice, Dyno Tuning, Fuel Management, Tuning Software, LS1 Edit, AutoTap, Diablo
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 10-10-2009, 06:14 PM   #1
crazychucky8
Junior Member
Default Shift Point Question?
Sorry guys, I know this may be a stupid question, but, I don't have experience in the tuning section. My brother-in-law has a silverado and wants to change his shift points with a hand held programmer. What is the difference and the effect of changing the shifts points negatively and or positively?
Thanks for the help!
crazychucky8 is offline   Reply With Quote
Old 10-21-2009, 01:21 PM   #2
tblu92
CF Senior Member
tblu92's Avatar
It's rather confusing---But at part throttle operation--the shift is commanded by 1 parameter comprised of throttle position & MPH--
At wide open--it changes--The engine has to hit 2 parameters in order to command a shift--1 is MPH and the other is RPM---
A true full tuner can adjust all these tables correctly--however a handheld can only make small adjustments because if you adjust it too far it won't shift at all----a handheld when adding MPH to the shift points can only add it in the Part throttle area- at WOT you can set the shift RPM up higher but NOT the MPH parameter-- A handheld does not address BOTH parameter for a WOT shift--so on a heavily modded car or if adding or subtracting too many MPH at WOT you won't be able too or it may not shift at WOT---most handhelds have limiters to prevent you from going too far on a stock engine---where you can get into problems is using a handheld on a heavily modded engine which the handheld shifting program is not sufficient to correctly make it shift
Sorry to confuse you--this is the long answer--
The short answer---Add 3 PH to the 1-2 shift maybe 1 or 2 to the 2-3 and 3-4 shifts---set the shift RPM to 5600 in 1st---5400 in 2nd and 5200 in 3rd--- set the safety rev limiter to 6000----
IF you have larger than stock tires only make the changes in the 1-2 shift--You won't have enough power on a stock engine to set the WOT shift RPM higher and it will hang and hang forever at the 2-3 and 3-4 points before it shifts
PS: most improvements on an automatic are done with a real tune--I've seen cars and trucks gain 4-5 tenths in the 1/4 mile times without adding a single HP-trans tuning-for the street the best improvements are in tuning the DOWNSHIFT tables--these arent even addressed in a handheld--
tblu92 is offline   Reply With Quote
Reload this Page Shift Point Question?
Tags
14, 2004, adjust, c5, change, corvette, difference, mile, parameter, point, points, shift, silverado, transmission, tuner
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
350 Turbo shift point adjustment question dogboy C3 Tech/Performance 12 01-02-2003 03:55 AM
'73 TH400 WOT upshift point question. ORVette C3 Tech/Performance 18 09-07-2001 09:14 PM
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
