Corvette Forum
Go Back   Corvette Forum > C5 Corvettes, 1997 - 2004 > C5 Scan & Tune
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
C5 Scan & Tune
Corvette Onboard Diagnostics, Service Advice, Dyno Tuning, Fuel Management, Tuning Software, LS1 Edit, AutoTap, Diablo
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 09-22-2009, 12:24 PM   #1
CarBoy
CF Senior Member
CarBoy's Avatar
Default How will dyno results change after gears?
Ok so last dyno result was 385rwhp, and that was before headers. I have not been able to get back for a retune since headers were installed and was hoping to do so, so that I could see what just the headers had done for me.
Well now I've gone and put 3:73's in the car and so things will be different, and will not be able to get the info I was wanting.
So here's my question.
Let's say I was @ 400rwhp and 400rwtq with the original 3:42's.
If nothing else changed but gears what would happen to those #'s?
CarBoy is offline   Reply With Quote
Old 09-22-2009, 01:33 PM   #2
pewter-FRC
CF Senior Member
pewter-FRC's Avatar
nothing. gears dont add horsepower. they increase acceleration
pewter-FRC is offline   Reply With Quote
Old 09-22-2009, 05:59 PM   #3
torkman15
CF Senior Member
Quote:
Originally Posted by pewter-frc View Post
nothing. Gears dont add horsepower. They increase acceleration
x2!
torkman15 is offline   Reply With Quote
Old 09-23-2009, 12:28 AM   #4
CarBoy
CF Senior Member
CarBoy's Avatar
Duh....I know they will not add HP but will the #'s read differently? Maybe not the HP # but would the torque reading come up differently? I'm not saying I'm adding or taking away actual hp/tq but will the dyno show a different # due to a gear change?
Like for example, would the peak #'s be the same but the rmp's in which those #'s are achieved is now at a different location in with in the curve?
Old 09-23-2009, 01:15 AM   #5
CTD
CF Senior Member
CTD's Avatar
Depends which dyno you are using, loss on the Dyno Jet, gain on the Mustang.
Many threads & posts on this!
CTD is offline   Reply With Quote
Old 09-24-2009, 03:16 PM   #6
ian@thetuningschool
Supporting Vendor
ian@thetuningschool's Avatar
Typically with shorter gears it will show a low number on the dyno, but not much.
Ian
ian@thetuningschool is offline   Reply With Quote
Old 09-25-2009, 08:51 AM   #7
BLOWNBLUEZ06
BLOWNBLUEZ06's Avatar
Quote:
Wrong. Gears will lower your readings on a dyno. Ask anybody that owns a dyno.
BLOWNBLUEZ06 is offline   Reply With Quote
Old 09-25-2009, 06:16 PM   #8
tail_lights
CF Senior Member
tail_lights's Avatar
Quote:
Ian
I think the torque 'band' shifts over a hair (down in the rpm band) and since hp is derived from tq and rpm the hp reading drops a few.
tail_lights is offline   Reply With Quote
Old 09-28-2009, 07:19 AM   #9
BLOWNBLUEZ06
It has more to do with loading the engine. Technically, gears shouldn't matter. The dyno has a RPM signal and measures the engines' ability to change the speed of the drum. Gears increase wheel torque, so it should be the opposite of what you're saying. At any given RPM, the true wheel torque will be higher since the factor is higher. On the Eddy current dyno at Taylors, I make less horsepower with no load applied, but that's not a fair comparison to a standard Dynojet because the drum of the eddy current version is ~2500lb versus 4klb on the standard version. (weights subject to my poor memory and per Taylor).
Reload this Page How will dyno results change after gears?
Tags
73, accesories, c5, change, changing, corvette, drum, dyne, dyno, gear, gearing, gears, post, readings, topic, tune
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
Z6 Air box w/ k&n worth getting? Big Phil C5 Tech 20 12-01-2004 10:45 PM
Charlotte Dyno Day Results (Stock '03 Z) niphilli2 C5 Tech 10 02-16-2004 06:28 PM
DYno Results for 406.....Coupled with MAF test. ski_dwn_it C4 Tech/Performance 61 05-29-2003 02:56 PM
4.10's = Lower Dyno #'s ? STL94LT1 C4 Tech/Performance 34 05-06-2003 10:18 AM
The "Supershark" will soon be launched MoMo Engine Mods 18 04-25-2002 11:36 AM
Port/polish stock Z06 heads, results anyone? WhiteDiamond C5 Z06 Discussion 39 03-19-2002 03:33 AM
Dyno Test Results!! Holy Moly! jimbr C3 Tech/Performance 17 01-26-2002 01:37 AM
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
