Corvette Forum
Go Back   Corvette Forum > C5 Corvettes, 1997 - 2004 > C5 Scan & Tune
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
C5 Scan & Tune
Corvette Onboard Diagnostics, Service Advice, Dyno Tuning, Fuel Management, Tuning Software, LS1 Edit, AutoTap, Diablo
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 09-16-2009, 06:55 PM   #1
T_Vert
CF Senior Member
Default Engine stalls when cold coming to a stop and randomly when hot
nothing has changed on the car as far as mods go so I know it probably isn't the tune. I assume in open loop the MAF isn't used so that isn't it. I'm going to have to log vacuum to look for a vacuum leak but anyone else have any input?? Maybe I should just play w/ the tune some?
Dave
T_Vert is offline   Reply With Quote
Old 09-17-2009, 04:06 PM   #2
tblu92
CF Senior Member
tblu92's Avatar
The car when started from dead cold will stay in open loop until the coolant temp reaches apprx 140* or hits the timer limit which is about 60 seconds. When the engine is warmed up--it will stay in open loop very briefly maybe 20 seconds.So if it is hot like you say and it has run over 20 seconds it is in closed loop----Sounds like it is weather related.more than likely the tune was on the borderline of needing some more adjustment-1st check for a vacuum leak and for all the usual suspects--If all looks well then most always you will need an adjustment in the "Desired Airflow" table --in gear---AND in the "Throttle Follower "table in-gear---In the desired airflow table you would add a % to correct dying/surging and in the throttle follower table you subtract a % to correct dying/surging----If you start getting a "Hanging idle" then you went too far and need to back them off----
tblu92 is offline   Reply With Quote
Reload this Page Engine stalls when cold coming to a stop and randomly when hot
Tags
c5, car, cold, coming, corvette, dies, engine, gear, hot, loop, open, put, stall, stalling, stalls, stop, stops, surges
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
