Corvette Forum
Go Back   Corvette Forum > C5 Corvettes, 1997 - 2004 > C5 Scan & Tune
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
C5 Scan & Tune
Corvette Onboard Diagnostics, Service Advice, Dyno Tuning, Fuel Management, Tuning Software, LS1 Edit, AutoTap, Diablo
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 09-13-2009, 03:17 PM   #1
hotparts
CF Senior Member
hotparts's Avatar
Default Help with the LC1 Innovate AFR Gauge
Hi Guys,
after two turns at the race track my LC1 suddenly showed me irrelevant values. At partial load it showed about 14,5, thats ok but at full throttle it shows at once 20 to 60 AFR. Normally i have about 11,3.
I let the car stay for about 12 hours and pushed the button three times for calibration after the oxygen sensor was hot and showed 20,9but at full throttle i had the same results. (Before starting i stopped the ignition and waited 30 seconds before starting the engine).
I let the car stay again and next day i pushed the button for three seconds after the sensor was hot but the results are the same again. (Before starting i stopped the ignition and waited 30 seconds before starting the engine).
What is the problem? Do i need to push a key combination to save?
Could it be that the sensor got too hot (normally it should be ok for 500 degrees celsius) with an 402 with the YSI and about 900 RWHP?
Thanks for help
hotparts is offline   Reply With Quote
Old 09-13-2009, 04:21 PM   #2
Beer99C5
Junior Member
St. Jude Donor '08
Beer99C5's Avatar
Send a message via Yahoo to Beer99C5
How old is the sensor?
I just replaced mine, 2 years old.
Normal driving it worked normally, At WOT it dropped to 12 or so then spiked to 20 + and stayed for a while (20 seconds or so).
Replacing the senor fixed mine. You can get them from a Volkswagon Dealer if you need quick turnaround, less than $60 IIRC.
__________________
1 of 245 1999 Nassua Blue Verts EFI LIVE TUNED
Forged 382 LS6 TFS 225 Heads Cam 232°/238° .595/.605@ 116° LSA
RPM Level V A-4 Yank 3000 w/ 3.42 gears
Two Stage Nitrous**Vararam Dry shot**Nitrous Outlet 102 Wet Plate**
Beer99C5 is offline   Reply With Quote
Old 09-13-2009, 04:37 PM   #3
hotparts
CF Senior Member
hotparts's Avatar
Mine is about 1,5 years but i used it only for about 6000 miles.
Was the approach ok or did i make a mistake (REset or Cal)?
Do you know the part number for the right sensor?
Could it be that the sensor gets too hot?
Thanks steve
Old 09-13-2009, 04:50 PM   #4
Beer99C5
Junior Member
St. Jude Donor '08
Beer99C5's Avatar
Replacement sensors are available from your nearest VW dealer under the VW part-number
021-906-262-B or direct from Innovate Motorsports.
I think your approach was Ok.
The instruction set has the sequence to get replace the sensor, its available at the innovate site.
__________________
Reload this Page Help with the LC1 Innovate AFR Gauge
Tags
afr, gauge, lc1
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
