Corvette Forum
Go Back   Corvette Forum > C5 Corvettes, 1997 - 2004 > C5 Scan & Tune
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
C5 Scan & Tune
Corvette Onboard Diagnostics, Service Advice, Dyno Tuning, Fuel Management, Tuning Software, LS1 Edit, AutoTap, Diablo
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 09-03-2009, 03:25 PM   #1
JJFormato
Premium Supporting Vendor
JJFormato's Avatar
Send a message via AIM to JJFormato
Default Formato tuning and porting in S. FL (Davie) Sept 10-11-12
Hello all, Jeremy will be tuning and porting in South Fl (Davie) on September 10th, 11th and 12th
Please call or PM for location (non sponsor shop)
The cost of tuning is $400 + $80 per hour for the dyno. If you are just looking for a street tune , that can also be done for $300 w/ WB o2. We work very hard on each and every vehicle until every customer is happy and the vehicle is spot on.
The average gain for the LS2 intake manifold is 11rwhp/13rwtq. We have done over 320+ LS2 INT manifolds, 90+ LS7s 18RWHP and 20RWTQ, 35+ LS3 & L76s 12RWHP and 15RWTQ and over 325+ TB's.We have had many cars gain much more than the averages listed: 20RWHP from an LS2, 32RWHP for an LS7, and 30RWHP from a L76 and 22RWHP from an LS3. When porting the TBs you will feel greatly improved throttle response and in the bottom end/mid range a strong seat of the pants increase. Many liken the difference to taking about 350lbs out of the vehicle. It truly makes the car much more fun to drive. Our Manifolds are very thoroughly ported not only in the runners but also much of the plenum and TB flange are enlarged in order to support more airflow from idle thru the upper RPMs. The larger the air reservoir the less likely it is to deplete the greater volume in the upper RPMs. Hence the difference of the '00 LS1 intake vs the '01 LS6 intake, a small plenum volume change gained 10RWHP and 10RWTQ.
This is all on a core exchange basis.
A $100.00 deposit via CC or Paypal is required to reserve a space.
To schedule a time, please call us at 813 476 7364 or Jeremy on his cell at 813 495 8778.
Here are some graphs of some cars that we dynoed, tuned, and swapped the intakes and TBs. Some are direct A-B swaps and show the results. Some are Base runs then a rough tune and then we swap the intake and TB, and then fully optimize the tune.
1st is a Stk 07 LS7 ported and tuned: 1st is base, 2nd is base tune, 3rd is ported and tuned completely.
Here is a bolt-on 07 LS7 (w/ headers CA)I base tune and then ported and tuned.
Here are two C6 LS2's with just cai and cat backs before and after tune and Ported intake and TB:
383 LS6 to ported FAST and nice set of heads:
408 LS6 to ported FAST:
Obviously the larger motors wanted the larger manifold more than a smaller motor but we have had an LS2 with one of our ported LS2s on it Put a ported FAST on there and pick up 22RWHP and 30RWTQ on a 6L bolt-on 07 vette.
Thank you
__________________
Independent GEN 3&4 LSX,LT1,L98 Tuner
PCM recalibrations LS7/LS3/LS2/LS1/LS6/LT1
Intake manifold and Throttle body porting Specialists LS7/LS3/LS2/LS9
Mail order tunes for 94-11 vehicles
Now carrying High Flow Injectors
www.fastprom@tampabay.rr.com
www.fasterproms.net
Office 813-476-7364
Cell 813 495 8778
JJFormato is offline   Reply With Quote
Old 09-04-2009, 12:31 PM   #2
JJFormato
JJFormato's Avatar
Some testimonials from here and various other LSx boards:
http://www.forum.grrrr8.net/showthread.php?t=10056
http://www.camaro5.com/forums/showth...710#post875710
http://forums.corvetteforum.com/c5-s...kr-issues.html
http://www.ls1gto.com/forums/showthr...hlight=formato
http://www.ssrfanatic.com/forum/f60/custom-tune-34230/
http://www.ls1tech.com/forums/florid...to-tuning.html
Reload this Page Formato tuning and porting in S. FL (Davie) Sept 10-11-12
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
