Corvette Forum
Go Back   Corvette Forum > C5 Corvettes, 1997 - 2004 > C5 Scan & Tune
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
C5 Scan & Tune
Corvette Onboard Diagnostics, Service Advice, Dyno Tuning, Fuel Management, Tuning Software, LS1 Edit, AutoTap, Diablo
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 08-27-2009, 09:48 AM   #1
KorbenDallas
CF Senior Member
KorbenDallas's Avatar
Default Whats the bucking problem with my car
I have a 230/232 Futral Motorsports FM13 cam on a 112LSA with 4 degrees of advance ground in, and patriot performance "special" LS6 heads. I've had this setup for 4 years+ and the power is nice. With the first tune I received the car behaved well around 1000-1200RPM for a few months and then the bucking started with anything below 1500.
I dealt with it for a couple of years then upgraded to a Z06 MAF, 30lb injectors, and received another tune from the same shop but different tuning tech. (They gave me a discount for a "retune".) The car drove even better than with the first tune, but again 4-6 months later the bucking problem came back. I have to ride through parking lots with the clutch half engaged, otherwise the car bucks violently.
I didn't think my cam was big enough that anything below 1500RPM would drastically buck. It seems like the tunes would last for a hot/cold season and then are crap for driveability. Wouldn't the MAF compensate for the different weather conditions? Is this typical of a head/cammed car to have to get a retune constantly? Or is there something else going on?
__________________
Click the image to visit my vette's info
1999 Navy Blue Coupe: HUD and MN6
Best Dyno: 435/400 rwhp/tq
Best 1/4: 11.72 @ 122mph
KorbenDallas is offline   Reply With Quote
Old 08-27-2009, 10:00 AM   #2
BLOWNBLUEZ06
BLOWNBLUEZ06's Avatar
Maybe your MAF is dirty and your numbers are drifting. Would have to log the car to see.
BLOWNBLUEZ06 is offline   Reply With Quote
Old 08-27-2009, 01:39 PM   #3
KorbenDallas
CF Senior Member
Quote:
Should I clean the MAF?
Old 08-27-2009, 10:21 PM   #4
mowton
CF Senior Member
mowton's Avatar
Are you using an oiled air filter...if so maybe a bit too much and your MAF is getting oiled. Get a good electronics part cleaner and just spray the elements...don't brush or touch them, they are fragile.
How many miles a month do you drive the car?
Ed M
mowton is offline   Reply With Quote
Old 08-27-2009, 10:48 PM   #5
Nver2loud
CF Senior Member
Nver2loud's Avatar
OH MY GOD, THIS IS EXACTLY WHAT MY CAR DOES!!!!!!!!!!!!!!!! I never knew how to really explain it, Ive tried over in tech and people were saying I had an intake leak. Im highly doubting that. I am still a stock cam, used to be charged before I bought it and still have large injectors. I even have problems on the highway with the cruise on if it gets to be going too slow and the rpms drop into the 12-1500 range. If you find a cure for this please let me know, it too is annoying to drive into work, people probably think I cant drive or something!
Nver2loud is offline   Reply With Quote
Old 08-27-2009, 11:01 PM   #6
mowton
CF Senior Member
mowton's Avatar
Both of you should find a member of your local Corvette Clubs that have HPTuner or EFIlive and scan for the problem. Much easier than quessing. If you buy them a drink, they will come
Old 08-28-2009, 03:14 PM   #7
Nver2loud
CF Senior Member
Nver2loud's Avatar
Someone in wisconsin, please have a need for alcohol!!!!
Old 08-28-2009, 09:33 PM   #8
vsocks1
CF Senior Member
vsocks1's Avatar
Quote:
PM or reach out to Tom (Y2KVert4me). He is in Pewaukee and pretty good at EFI Live. I have it also, but am in Belgium, WI and not as skilled as Tom. Let me know if you still need a hand sometime!
vsocks1 is offline   Reply With Quote
Old 08-29-2009, 10:33 PM   #9
KorbenDallas
CF Senior Member
Ed M
Good call; the MAF was oiled from my K&N filter. I cleaned it and went for a test drive, but unfortunately it didn't fix the problem or improve anything.
Old 08-30-2009, 10:09 AM   #10
mowton
CF Senior Member
mowton's Avatar
Quote:
It may take 50-100 miles for the trims to re-learn
Old 08-30-2009, 09:42 PM   #11
KorbenDallas
CF Senior Member
Thanks, it might be a while since the vette is a weekender when it's not raining in FL
Old 10-03-2009, 10:32 PM   #12
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Support Corvetteforum!
Bill Curlee's Avatar
Pull the PCM fuses and that will reset your LTFTs. Then see if it gets a little better.
BC
Bill Curlee is offline   Reply With Quote
Old 10-06-2009, 06:44 PM   #13
frcslave
CF Senior Member
Like Bill Curlee said - check your LTFT's. Sounds like your O2 sensors are gradually moving your tune away. Easy enough to check... if that is the problem you may consider turning them off completely and running with the STFT's only. Good luck,
Gabe
BTW - where is Green Cove Springs? I am in Cape Canaveral.
frcslave is offline   Reply With Quote
Old 10-06-2009, 07:39 PM   #14
SDPC
Premium Supporting Vendor
SDPC's Avatar
Send a message via AIM to SDPC
I have seen it happen with injectors that are too large.
SDPC is offline   Reply With Quote
Old 10-07-2009, 01:14 AM   #15
joopblog
Junior Member
joopblog's Avatar
Send a message via Skype™ to joopblog
Default Mine did the same, was electrical interference
My stock '02 Z06 did it when I first got it 3 years ago. It started bucking right away, took it to the Chevy stealer, and it took them a week to find the issue. It turns out the wiring going to the MAF was either causing electrical noise or was receiving electrical noise. They wrapped the wiring with aluminum wiring shield and it solved the issue.
joopblog is online now   Reply With Quote
Old 10-07-2009, 01:50 PM   #16
iced98lx
CF Senior Member
Depending on the size of injectors that is quite possibly your problem. Running huge injectors at tiny duty cycles can be hard, the spray pattern etc isn't going to be as uniform as a smaller injector. Plus, depending on the tuner, you might not have all the right injector data in the tune in the first place. If you haven't got need for the bigger injectors sell them off and put stock ones or even SVO red tops in with accurate injector data and you'd be amazed how much better the car will run.
iced98lx is offline   Reply With Quote
Reload this Page Whats the bucking problem with my car
Tags
2005, bucking, bucks, c6, cam, car, drive, fm13, futral, highway, maf, problem, problems, put, raining
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
Only 12 Hours to go for the Show and Go Spinal Sh0ck Drag Racing 12 08-08-2004 11:16 PM
tracking down a miss at idle on 94 auto gsxrjack C4 Tech/Performance 22 03-23-2004 08:14 PM
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
