thezman
Your best bet is to post technical problems over in the C5 Tech section. I was looking in the scan and tune for EFI Live help and saw your post.
That valve is inside the Brake Pressure Modulator Valve (BPMV) and NON SERVICEABLE. The COIL that causes that valve to operate is in the Electronic brake Traction Module (EBTCM)
Here are pictures of both:
EBTCM:
Coils that operate the solenoid valves:
BPMV with Solenoid valves:
If I were you, I would disconnect the main connector to the EBTCM and examine the connector the plug and the wires inside the connector for damage. Make sure that the connector is in good shape.
Bill
