Corvette Forum
Go Back   Corvette Forum > C5 Corvettes, 1997 - 2004 > C5 Scan & Tune
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
C5 Scan & Tune
Corvette Onboard Diagnostics, Service Advice, Dyno Tuning, Fuel Management, Tuning Software, LS1 Edit, AutoTap, Diablo
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 08-18-2009, 11:40 PM   #1
FLAFLIER
CF Senior Member
Default New Magnuson Tune Question
I will be installing a 112 Maggie on my 99 FRC. The car has a Lingenfelter top end kit GT2 cam , heads , intake , LG longtube and a B&B cat back , with of course a Lingenfelter tune @384 rwhp.
the question is since I bought the complete system used and the superechips tuner was for a 02 automatic i cant download the initial tune from the tuner , will I be able to gently drive the car to get it Dyno tuned , or will I need to trailer it ? Distance to the Dyno is about 60 miles.
FLAFLIER is offline   Reply With Quote
Old 08-19-2009, 01:07 PM   #2
tblu92
CF Senior Member
tblu92's Avatar
I would say yes---If it starts -runs and shifts it should be OK--Of course a must would be to take it easy--Do not get it into Power enrich.---at part throttle it will be in closed loop so it will should be safe as long as there is little or no boost---The headers by installation will richen up the commanded closed loop AFR of 14.68 anywaymaking it quite rich---You may have a "war & peace " script of codes
tblu92 is offline   Reply With Quote
Old 08-19-2009, 02:48 PM   #3
FLAFLIER
CF Senior Member
Thanks for the information Blu. sounds like the key to that is try to start , then see what happens from there ? When I make a decision on which dyno turner I use , is an alternative take the computer to that tuner to have him do initial adjustments , then re install to the car, or am I just wasting his and my time ?
Old 08-19-2009, 05:43 PM   #4
Y2Kvert4me
CF Senior Member
CI 6-7-8-9-10 Veteran
St. Jude Donor '03
Support Corvetteforum!
The problem you may run into would be setting a P1514 and Reduced Power mode with the presence of any boost, and Roots-style blowers produce boost at a very low RPM (compared to centrifugal blowers), so it might be difficult to avoid.
But, since you are already tuned for heads/cam, the table responsible for causing that might already be modified such that it may not be an issue.
Easy enough to try and drive it a few blocks after installation, and see what happens. If you don't hit REP mode in normal driving, then it should be ok to drive it to the tuner.
Y2Kvert4me is offline   Reply With Quote
Old 08-19-2009, 05:46 PM   #5
Y2Kvert4me
CF Senior Member
St. Jude Donor '03
Also, if the Maggie kit came with larger injectors, they would cause a problem too.
Leave your current injectors in place until you get it to the tuner.
Old 08-20-2009, 02:31 PM   #6
tblu92
CF Senior Member
tblu92's Avatar
Yeah the p1514 DTC will put it into a reduced power mode and will only let you drive it 25 MPH or so--and it will run like crap---However--you and reset that code and it will run normal again by turning the ignition on and off 3-4 times---When driving it again you have to really baby it--the more load you put on it will make it set again--the shifts are usually where it will set--If you are just driving around town and not on the freeway--drive it in 2nd the whole time to avoid shifting---
Old 08-20-2009, 04:47 PM   #7
FLAFLIER
CF Senior Member
So I take it the engine will probably run super rich? Does that meen I will wipe out the o2 sensors?
Old 08-21-2009, 02:19 PM   #8
tblu92
CF Senior Member
tblu92's Avatar
slight chance but as long as the 02 heaters are working and you don't run it too long it should be fine--
PS even in a stock engine while it is in power enrichment the 02's are not being used and the PE afr is pig rich in the 11.0 range-- so it should be ok
Old 08-24-2009, 03:24 AM   #9
sami85L98
CF Senior Member
sami85L98's Avatar
y2kvert4me and tblue, is correct, i just install FAST 90/90 on my bolt on car, and P1514 was throwing at me the moment u drive a block, otherwise starts fine idles fine, so i bought EFIlive tuner and first thing i did is change 20+% on ETC table, man what a peace of mind.
On a maggie iam 99% sure u will have to be dealt with p1514 code, unless Lpe has modiied that table and increase by certain percentage than u should be ok.
When u get P1514 code u get reduced engine power REP and CEL, car will still run but barely u can limb home if u r few blocks away though, car will down on power big time.
I also bought maggie head unit and now i have to find hood and other maggie parts.
sami85L98 is offline   Reply With Quote
Reload this Page New Magnuson Tune Question
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
Used polished Mag for sale $5,695.00 installed Chris@East Coast Supercharging C5 Forced Induction/Nitrous 23 05-20-2004 05:26 PM
Magnuson SC, What Is "THE REAL STORY"? vetman90 C5 Forced Induction/Nitrous 19 01-16-2003 09:31 PM
New Performance shop / Lingenfelter authorized dealer NOEXCUSES C5 Tech 105 08-25-2002 11:38 PM
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
