Corvette Forum
Go Back   Corvette Forum > C5 Corvettes, 1997 - 2004 > C5 Scan & Tune
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
C5 Scan & Tune
Corvette Onboard Diagnostics, Service Advice, Dyno Tuning, Fuel Management, Tuning Software, LS1 Edit, AutoTap, Diablo
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 08-17-2009, 05:14 PM   #1
hotparts
CF Senior Member
hotparts's Avatar
Default Fast Intake broken at 16 psi
Hi guys,
the lower shell of my 92 mm Fast intake is broken because of the more psi of the YSI charger. Do you know a strenghened lower shell?
Where to order the lower shell cheap?
hotparts is offline   Reply With Quote
Old 08-17-2009, 05:31 PM   #2
user_name
CF Senior Member
user_name's Avatar
Send a message via AIM to user_name Send a message via Yahoo to user_name
They actually sell burst caps that you install on the same lower shell. Seems to me like it should be build a little stronger for the money, but it isn't.
user_name is offline   Reply With Quote
Old 08-17-2009, 06:57 PM   #3
sami85L98
CF Senior Member
sami85L98's Avatar
I cracked mine, not using flat valley pan bolts, it was dimple cracks,
i fixed it by JB weld, sanded rough first with 40 grit paper and removed dirt with acetone,
and than applied JB weld, i re-did second day as well and last installed perfect worked nice.
But if u r runnning that much boost than install LS6 intake which is lot stronger than FAST intake f*@!*$! cheap plastic piece that u paid 4 times the money.
sami85L98 is offline   Reply With Quote
Old 08-17-2009, 08:19 PM   #4
TRIZ
CF Senior Member
TRIZ's Avatar
I've seen two break with just N/A.
Install a ported LS6 unless you have a lot of money.
I'm running a YSi too (just installed it) but with only 20 psi.
TRIZ is offline   Reply With Quote
Old 08-18-2009, 12:26 PM   #5
tblu92
CF Senior Member
tblu92's Avatar
""I cracked mine, not using flat valley pan bolts, it was dimple cracks,
and than applied JB weld, i re-did second day as well and last installed perfect worked nice """""
I had the same issue with my Fast 78--However i was for warned about the bolt heads---So I pre instaled some shallow button head allen bolts---even then i checked the clearance by placing "white out' ot the bolt heads and installing about 3 bolts on each side semi-tight and still a few of them touched---i had to use a dremmel to clearance those--
I agree--for the $$ you would think the fit and finish of a Fast would be perfect--looking inside one there are so many turbulent areas that could have been molded better----If i were to do it again i would stick with the LS6 intake or try the TPIS Oval---
tblu92 is offline   Reply With Quote
Old 08-18-2009, 02:35 PM   #6
joshtownsend
CF Senior Member
joshtownsend's Avatar
Anybody try the Weiand street warrior?? I heard they were not going to make them but Summit keeps advertising they have them. Seems a one piece is the way to go as its more structuly sounds then a 3 piece intake.
joshtownsend is offline   Reply With Quote
Old 08-25-2009, 07:32 PM   #7
ajg1915
CF Senior Member
St. Jude Donor '08
Support Corvetteforum!
ajg1915's Avatar
If you're going to be boosted, why not use a LS2 90mm intake. They're cheep and plentyful.
ajg1915 is offline   Reply With Quote
Old 09-24-2009, 05:06 PM   #8
hotparts
CF Senior Member
hotparts's Avatar
does anybody know how to get a lower shell and the burst caps for the fast? I sent an email weeks ago but Fast didn`t response.
Old 09-25-2009, 08:49 AM   #9
BLOWNBLUEZ06
BLOWNBLUEZ06's Avatar
I know you're out of the country, but maybe you can call them. I can get you a ported LS2 intake for a very reasonable price if you need. It won't break like that under boost.
Tsus!
BLOWNBLUEZ06 is offline   Reply With Quote
Old 09-25-2009, 06:16 PM   #10
tail_lights
CF Senior Member
tail_lights's Avatar
Ditch the FAST and get an LS6/2
tail_lights is offline   Reply With Quote
Old 09-29-2009, 06:02 PM   #11
Luweegy
CF Senior Member
Luweegy's Avatar
Send a message via Yahoo to Luweegy
Fast intakes and Hi-Tech hoods must be made by the same company.Both POS non fitting junk in my book.All that $ and have to modifiy them to no end to work.Then they break.
Luweegy is offline   Reply With Quote
Old 09-29-2009, 07:38 PM   #12
jmoody66
CF Senior Member
Im at 10 or 11 lbs now and so far so good....I wish I had known before spending all that money on mine....and its ported so Im sure I have weakend it more. At least I know what to expect.
jmoody66 is offline   Reply With Quote
Reload this Page Fast Intake broken at 16 psi
Tags
92mm, c5, c6, cheapest, corvette, cracked, fast, forum, intake, l92, pictures, psi, read, street, tune, vette, warrior, weiand
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
