Corvette Forum
Go Back   Corvette Forum > C5 Corvettes, 1997 - 2004 > C5 Scan & Tune
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
C5 Scan & Tune
Corvette Onboard Diagnostics, Service Advice, Dyno Tuning, Fuel Management, Tuning Software, LS1 Edit, AutoTap, Diablo
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 08-16-2009, 12:06 PM   #1
CAP'N GEOFF
Junior Member
Default '98 c5 no start
Hi everyone, need help with my 98 C5
Car ran great with no hassles for a year
Pal bought it from me after the Man took my license
His "help" power-washed the car (!) one day and ever since we have had hassle.
Started with warning codes such as reduced power, abs, etc. then wierd behaviour from engine, sometimes ran strong, then coughed & gave up.
Now she will not fire at all.
Got P1635 code off OBD2 scanner.....
Any ideas?
CAP'N GEOFF is offline   Reply With Quote
Old 08-16-2009, 02:46 PM   #2
tblu92
CF Senior Member
tblu92's Avatar
Read this---- http://gearchatter.com/viewtopic9428...489ea316b6fe92
More than likely you got water into the PCM connecter or plug- OR the hi-pressure stream when washing unpluggeg it or pulled a wire out- the diagnosis is rather complex but read the red writing and it will give you a 1st thing to look at--then if you have someone or can do it yourself--follow the diagnosis proceures and fixes
tblu92 is offline   Reply With Quote
Old 08-17-2009, 05:35 AM   #3
CAP'N GEOFF
Junior Member
Hi, tblu92 ; many thanks for replying and the very comprehensive info: will do as suggested and report results.
Is the PCM the alloy-cased box of tricks sited below the battery tray (!)
Seems a great place to locate it ( irony for GM ....)
Cap'n Geoff in Scotland.
Reload this Page '98 c5 no start
Tags
98, c5, start, times
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
97-98 CLB Not Working? Then use the *GM* Column Lock Bypass TorchRedRaider C5 General 32 12-16-2004 08:58 PM
Whats the first mods to do to a C5? WantstobuyaVette C5 Tech 27 10-06-2004 05:52 PM
C4 VS C5 VS C6 loflite C4 General Discussion 58 01-09-2004 08:25 AM
Early ZR-1 vs low miles LT4 vs C5 MN6 DriveItHard! C4s for Sale/Wanted 17 12-09-2002 04:08 PM
B&B PRTs on a '98 TomZ06C6 C5 Tech 54 10-24-2001 06:12 PM
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
