We are offering a group purchase for the new Innovate Motorsports LM-2 basic wideband O2 sensor and controller.
The new LM-2 "Basic" Kit (Single Wideband O2) includes the LM-2 meter, Bosch wide-band oxygen sensor, 8 ft sensor cable, cigarette-lighter power adapter, USB cable for PC connection, weld-in bung and plug, LogWorks software CD, and quick-start guide.
Forum Group Purchase price $315 (retail is $349) + shipping
LM-2 Basic
We will also sell the standard LM-2 kit for $425 (retail is $479) + shipping
LM-2 standard
And the Dual Wideband kit for $599 (retail is $669) + shipping
LM-2 Dual sensor
ADDED Wideband sensor and controller $185 (retail is $199) + shipping
LC-1
The LM-2 combines an air/fuel ratio meter, a full-function 32-channel datalogger, and powerful software to deliver a complete tuning workshop for less than the cost of one dyno day. Whether you have a piggy-back fuel controller, race carb, aftermarket ECU, ODB-II tuning software, or a flash/chip programmer, an LM-2 is the tool you need to dial in maximum HP. The meter’s award-winning digital signal processing technology provides data on exactly how rich or lean an engine is running at any load. The LM-2’s self-calibrating circuitry also compensates for changes in temperature, altitude, and sensor condition.
• Patented “Direct Digital” Wideband Technology
• Wideband O2 Compatible with ALL fuel types
• Single or Dual Channel Version Available
• OBD-II Scan tool- read/clear DTCs and log up to 16 channels of CAN OBD-II Data (with optional cable)
• Log directly to SD card (optional)
• Playback log data on screen and/or with powerful LogWorks software (included)
• Large high-contrast graphics LCD
• Built-in RPM converter (direct frequency or with optional inductive clamp)
• 4 fully-differential analog inputs (with optional cable)
• 2 configurable linear analog outputs (with optional cable)
• Positive lock connectors for all connections
• Innovate MTS serial IN and OUT
• USB connection to your PC
The LM-2 also features two fully programmable linear analog outputs to connect to analog gauges, dyno computers, ECUs, piggyback controllers, and other devices with analog inputs. Analog output 1 comes setup from the factory ready for narrowband simulation; analog output 2 is configured as 0 volt = 7.35 AFR and 5 volts = 22.39 AFR. With the provided LM Programmer software these analog outputs may also be configured by the user.
LM-2 basic includes
• Handheld LM-2 Meter
• Bosch wide-band oxygen sensor
• 8 ft sensor cable
• Cigarette-lighter power adapter
• USB cable for PC connection
• Weld-in bung and plug
• LogWorks software CD
• Quick-start guide
