C5 Air-Conditioning
C5 Air-Conditioning
C5 Drivers side air does not blow, passenger side is cold and works fine. Any help appreciated before I take it to the dealer. It acts as if the Blower is not working. I don't feel any cold air to speak of. Thanks in advance.
never had the problem, but from reading on the forum it is usually an issue with vacuum. Vacuum is leaking somewhere probably. Door actuator probably not opening. BTW, this post should of gone in C5 gen or tech to get a better response.
I had the problem of drivers side hot and pass side cold after a tune and I had to reset the ac door actuators. you can do it by rewriting the tune or disconnect the battery for a few minutes and reconnect. If it was working fine before you wrote the tune it will probably fix it. Be sure when you write a tune you dont have anything drawing power from the battery like radio, dome lights, ac fan, auto headlights, ect...
