Corvette Forum
Go Back   Corvette Forum > C5 Corvettes, 1997 - 2004 > C5 Scan & Tune
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
C5 Scan & Tune
Corvette Onboard Diagnostics, Service Advice, Dyno Tuning, Fuel Management, Tuning Software, LS1 Edit, AutoTap, Diablo
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 05-18-2009, 02:39 PM   #1
chuckster
CF Senior Member
chuckster's Avatar
Send a message via AIM to chuckster
Default Upgraded to a Z06 85mm MAF do I need to change anything other than the MAF Table?
I am basically Stock.. I used HP tuners to update the MAF table of my 2000 with the 2002 table..
I fired it up today while still on Jackstands.. I let it idle till full warmup then I logged it on Tuners. I noticed that the LTFT trims were running about Positive 9-10... WTF? that makes no sense.. Even my old tune before the MAF had the Injectors bumped up a slight bit to keep my trims negative 5-6...
Why would this bigger MAF swing the LTFTs so much?
I Reset the Trims using the realtime options while idling.. The STFT's were in the negatives a bit.. but the LTFT's were still like 10+
I realize the LTFT are calculated over a longer time.. and I probably need to drive it. Should I ignore this until I get her on the road and drive it a bit?
By the way.. idle and blipping the throttle to almost WOT seems to respond fine..
chuckster is offline   Reply With Quote
Old 05-19-2009, 03:40 PM   #2
69lt1bird
Junior Member
Why would you "bump up your injectors" to fix a trim issue. If you have HP tuners, just tune it right. The MAF table needs to rescaled to your vehicle. Setup hp tuners to be MAF only, get a wideband and tune it.
69lt1bird is offline   Reply With Quote
Old 05-19-2009, 04:10 PM   #3
chuckster
CF Senior Member
chuckster's Avatar
Quote:
The MAF was already Rescaled using the Factory 2002 Z06 MAF Table..with my HPtuners
As far as the Trim using the Injectors..
I originally tuned the car with LS1Edit.. I bumped a 1 or 2% across the board on the injector rate. this creates a rich condition thus forcing the PCM to PULL fuel and create a (Negative Trim)
Its common practice to have Negative Fuel trims before tuning WOT. Allegedly..if you are adding fuel (Positive Trims) it makes WOT tuning more difficult..Because it would potentially add it to the PE.. In a negative Trim nothing can be pulled or added to PE..
Again, By forcing the injectors a bit richer.. the System Pulls Fuel.. and creates a Negative.. The Optimal was about -3 to -5...
Old 05-22-2009, 03:29 PM   #4
WEB AIR
CF Senior Member
WEB AIR's Avatar
If you're tuning fuel trims, it takes anywhere from 50 to 100 miles for your PCM to learn your new tune. You want your short term trims to be 0 or as close to it as you can. You should never mess with the injector flow rate but should reset the maf table to fine tune your trims. There are all kinds of examples on the HPT website.
WEB AIR is offline   Reply With Quote
Old 05-22-2009, 05:50 PM   #5
Slowhawk
Premium Supporting Vendor
You should also upgrade the VE table to the 02 Z06 table too.That will work better with the MAF.There is no problem moving the injector table and you don't need a wideband.
__________________
2011 Camaro SS ,synergy green -shop car
ARH headers,intake,Cam ect so far. 11.66 at 116mph weighing 4065lbs.
Old car-2002 Electron blue C5
Z06 catback,Edit tuned.
A+A P1 kit,Kook longtubes
507hp/477tq
2005 Avalanche,SOM,Corsa,tuned ,Single turbo kit 450hp/475tq at 7lbs of boost.
1999 Trans Am -420ci C5R motor -daily driver -10.2 at 130mph NA
Owner of www.Slowhawkperformance.com
LS1 tuning/building.
Slowhawk is offline   Reply With Quote
Old 05-22-2009, 09:48 PM   #6
Cantalope Kid
Junior Member
IFR table rapping is NOT tuning...
Also don't just copy over a ZO6 VE table.
Actually tune the damn thing!
Put your injector values back to stock. Now tune your VE table as your should have from the beggining in SD mode.
Cantalope Kid is offline   Reply With Quote
Old 05-22-2009, 10:35 PM   #7
chuckster
CF Senior Member
chuckster's Avatar
Chill Dude... I realize it was not tuning..
I simply want to get the car running solidly before I start my tuning process..
If you were tuning in the early 2000's and ever used LS1edit or a MAF Translator... You'd know There were OTHER methods that worked fine..
When I had LS1edit I SELF "STREET" tuned my car using the injector Rate and the PE Tables to get the following Dyno Sheet
We were going to do a Wide Band tune but after that pull the tuner said leave it.. it looked good..
Old 05-22-2009, 10:47 PM   #8
chuckster
CF Senior Member
chuckster's Avatar
Quote:
That sounds like a good idea to get me started... I also have an LS6 Intake Manifold so it should look just like a Zo6 from an airflow standpoint
With the exception of the injectors and heads and Cam..
But the VE table should be ok to copy? Gonna put the injectors back to stock..
Reload this Page Upgraded to a Z06 85mm MAF do I need to change anything other than the MAF Table?
Tags
2002, 85, 85mm, gto, hp, increase, maf, mm, require, table, translator, tune, tuner, tuning, z06, z06style
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
