Corvette Forum
Go Back   Corvette Forum > C5 Corvettes, 1997 - 2004 > C5 Scan & Tune
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
C5 Scan & Tune
Corvette Onboard Diagnostics, Service Advice, Dyno Tuning, Fuel Management, Tuning Software, LS1 Edit, AutoTap, Diablo
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 05-13-2009, 11:13 PM   #1
blackfrc500
Junior Member
Default Emissions Problem
I have a 1999 FRC with cam/heads/intake/long tube headers with hp cats, won't pass emissions in Rhode Island, is there a tuner in the area that can help me out, does it need to be dyno'd. Any help on this would be greatly appreciated. Thanks, Bill
blackfrc500 is offline   Reply With Quote
Old 05-14-2009, 11:12 PM   #2
tblu92
CF Senior Member
tblu92's Avatar
Depends on WHY it won't pass---Do you have any codes ?? Or will it not pass because of high NOX or HC's ?
A tuner can get rid of all the codes associated with your mods
Your biggest challenge will be the LT's----The 02 sensor location on LT's is usually further back then they were with stock manifolds--this makes your 02's give erroneous readings in closed loop (part throttle) even though the ECM and 02's are commanding a 14.68-1 AFR you are probably ending up with something much richer--more likely 12.1
Another issue is your Hi-flow cats---many of them won't pass emmisions--The bullet types are known especially for this--Since Jan of 09 the smog police have really cracked down on cats--here in calif they look to see if there is any new welding on your exhaust--If so you must have cats that are on the approved list or they will not pass you-Also before if a car was over 10 years old you could change them without a problem--NOW the car has to be older than a 98 before you can legally change them--And i assume every year they may change that date---
Good news is that a tuner can correct the codes--Correct the 02 false readings so you get 14.68-1 again in closed loop--a wideband is neeeded---I would get it tuned 1st--then depending on which cats you bought--make a decision on those--
tblu92 is offline   Reply With Quote
Old 05-15-2009, 04:19 PM   #3
blackfrc500
Junior Member
I found a dyno tune shop that is familiar with these cars and will be able to help me out. You were RIGHT ON with the cats. Thanks so much for your reply, I printed out your reply and brought it to the shop, we will be taking your advice. Thanks again tblu92!!!
Reload this Page Emissions Problem
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
Starting problem.. 1989 C4 SkipI C4 Tech/Performance 113 05-11-2010 08:03 PM
FAILED emissions....WTF???? NEW77GUY C4 General Discussion 26 04-20-2003 03:00 PM
Emissions problem: CO too high damionvoss C4 Tech/Performance 9 03-29-2002 10:17 PM
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
