Corvette Forum
Go Back   Corvette Forum > C5 Corvettes, 1997 - 2004 > C5 Scan & Tune
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
C5 Scan & Tune
Corvette Onboard Diagnostics, Service Advice, Dyno Tuning, Fuel Management, Tuning Software, LS1 Edit, AutoTap, Diablo
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 05-11-2009, 03:24 AM   #1
imma_stocker
Junior Member
Default tune only still stock?
My dad has a 2000 with 13,387 miles. We really want to keep it stock. The original tires are actually getting a little dry rot so the back end kicks out a little more often than we like. But I digress...
What is CF.com's opinion on getting a tune only? Is it still stock if we don't change anything else?
imma_stocker is offline   Reply With Quote
Old 05-11-2009, 12:48 PM   #2
Brian@RPT
Supporting Vendor
Brian@RPT's Avatar
I say yes. Even in stock form, there are many things you can do to get the most out of the Vette. If it is automatic, there is even more. I can help you with any tuning
Brian@RPT is offline   Reply With Quote
Old 05-11-2009, 02:58 PM   #3
imma_stocker
Junior Member
It is an M6, fully loaded with the electromagnetic suspension control.
What can be done in stock form?
Old 05-11-2009, 04:25 PM   #4
Brian@RPT
Supporting Vendor
Brian@RPT's Avatar
Mine is also a M6 and MagRide on an LS3. I gained 20 rwhp from tuning but, the low to mid end is the greatest improvement. The car is much more responsive and I reduced the torque manangement. That was a big improvement and optimized the fueling tables using a wideband. Overall, it was worth it and the runflats will have to go I also optimized the fan temps for a stock thermostat.
Old 05-13-2009, 11:19 AM   #5
alxltd1
CF Senior Member
St. Jude Donor '10
alxltd1's Avatar
Quote:
I have a stock 2000 M6 except for a cold air intake and had it tuned by a forum member (phils C5 vette). He also reduced the torque management for noticable improvements in throttle response. Haven't had the car on a dyno so don't know if there was any HP gain, but the seat of the pants meter says something good happened. In addition, he removed that pesky 1 to 4 shift lock out and indicator light (though why the dash light disappeared is a mystery to me as everything I read said you could bypass the lock out but the light would still appear, but I am not complaining). Now if tuning would only fix my hazzard switch I would be a very happy puppy!
alxltd1 is offline   Reply With Quote
Reload this Page tune only still stock?
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
8 mph Trap gains from cam only!!!! rwj383 C5 Tech 13 05-17-2005 05:29 PM
mailorder chips unlocked kvu C4 Scan & Tune 112 04-14-2005 09:59 PM
Stock Z06 plus AFR Heads!!!!! stano C5 Tech 50 07-17-2004 11:11 PM
LG Motorsports: Raised Bar on Cam Only Record G5X3 Godspeed C5 Tech 54 05-18-2004 04:22 PM
New Best ET on stock L98 TPI! Mad-Mic C4 Tech/Performance 121 11-02-2003 06:05 PM
03 Z06 Change From Zip Tie Mod to Vararam 427CPE C5 Z06 Discussion 45 10-01-2003 11:48 AM
XTREME M.S. Will Dyno tune any LS1-6 100% correct davidmax C5 Scan & Tune 13 08-05-2002 11:17 PM
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
