Corvette Forum
Go Back   Corvette Forum > C5 Corvettes, 1997 - 2004 > C5 Scan & Tune
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
C5 Scan & Tune
Corvette Onboard Diagnostics, Service Advice, Dyno Tuning, Fuel Management, Tuning Software, LS1 Edit, AutoTap, Diablo
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 05-10-2009, 01:25 PM   #1
baezi z06
CF Senior Member
baezi z06's Avatar
Bæring Jón Skarphéðinsson
Send a message via MSN to baezi z06
Default 408 or? need help...
hi
i´m from iceland
i´ve got Z06 2004, whith a little damadged crank, and block, all fixable, but i´m not trusting this things any more, had before damadge on two pistons they slammed upto valves, so i´m now in 2nd time opening the motor the cause of damadged now on the crank and block , was piston bolt got loose and so on .....
just wante new stuff. (bigger.....)
I had dynotest of the (346) motor 424rwhp at 6500rpm , it is ls6 whith TFS215cc and Comp cam 281/283 232/234 .595/.598 112 LS, very high lift in that motor, made trap time 123.6mph the 1/4 mile
and then harland-sharp 1-7, MSD, Mt1 ramair, kooks headers, no cats, ls6 throttlebody and ls6 intake manifold, spec 3 clutch (hurst shift)
not sure the numbers on the injectors (but they are not orginal, it´s often rich of fuel, never lean)
so i´m looking for the best small block stroker, that i could buy and use whith my other stuff. and then in the future will do mods(bigger fast, bigger cam and maby no2), i´m both driving and racing.would like it hard core....
have been looking at 408, and 416, 418.
what do you think, ?
need good performance result but... low budged , and able to use my other stuff for now...,
and need fast deliverie whith fast shipping to iceland
kv baering
baezi z06 is offline   Reply With Quote
Reload this Page 408 or? need help...
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
Vette in early...need GMID ASAP! cbr_streetgang C6 Corvette General Discussion 21 05-22-2005 05:40 AM
Need help on what Torque Converter to use with 408 Stroker FastCashDave C5 Tech 10 05-12-2004 07:53 PM
I don´t find 42 lbs injectors anywhere....need help!!!!!!!!! Austrian Vette C5 Tech 22 12-09-2002 12:27 AM
Fired up my new 408 sbc!! TeenagerWith74Vette Engine Mods 24 10-19-2002 10:08 PM
Will be racing a ricer soon... ***Need your input*** Cookwithvette C3 Tech/Performance 36 09-21-2002 10:43 PM
How Much Do I Need for the 10's VICOUS C5 Tech 33 04-12-2002 04:58 PM
Need help finding a neutraly balanced flywheel 88-406 Engine Mods 11 11-25-2001 10:02 PM
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
