Corvette Forum
Go Back   Corvette Forum > C5 Corvettes, 1997 - 2004 > C5 Scan & Tune
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
C5 Scan & Tune
Corvette Onboard Diagnostics, Service Advice, Dyno Tuning, Fuel Management, Tuning Software, LS1 Edit, AutoTap, Diablo
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 05-09-2009, 11:14 PM   #1
Vette N It
CF Senior Member
Vette N It's Avatar
Default Do these numbers look right?
I have a 2000 MN6 vert and back on April 4, 2009 I went to have it tuned on a Dynojet 424x. At the time I had just a Blackwing and Borla Stinger attached to the stock H pipe. Before the tune I managed a run with 332HP and 342 Torque, after the tune I had 340HP and 348 Torque. 65 degrees, 28% humidity, SAE 0.99.
Yesterday I put some 1 3/4 LG Street Series LT's on with high flow cats. Today I went down to the dyno.The new numbers are 349HP and 358 Torque. 81 degrees, 30% humidity, SAE 1.02. AF ranged from 13.0 at 2k rpm's to 12.8 at 6400 rpm's.
To my knowledge the car has no other bolts on's except the Blackwing, LG's, and the Borla. Now I'm sure there will be a few calling , but do these numbers seem possible? I am sitting here looking at the sheets rights now.
Mike
Vette N It is offline   Reply With Quote
Old 05-10-2009, 10:37 PM   #2
0331MARINE
CF Senior Member
Support Corvetteforum!
0331MARINE's Avatar
Location: You know your drunk when you swerve to miss the tree then you realize its your air freshener! Fallbrook CA
Send a message via AIM to 0331MARINE Send a message via Skype™ to 0331MARINE
I ran into the same thing with my 2001 MN6. I have full bolt ons and a MS3 cam and mine put down 412.6 and 385.8. I didnt think it was right but I put it on another Dyno and got 411.9 and 387.6.
0331MARINE is offline   Reply With Quote
Old 05-11-2009, 04:33 PM   #3
Brian@RPT
Supporting Vendor
Brian@RPT's Avatar
That looks normal for a M6. I had a 1998 Trans Am and thru a stalled A4, I put down 325rwhp using Hooker Longtubes and Airlid. That car only dynoed 282 rwhp is stock form. A friend of mine had a 1998 Camaro SS M6 and dynoed 312 rwhp bone stock.
Brian@RPT is offline   Reply With Quote
Old 05-11-2009, 06:50 PM   #4
95BlueBomber
CF Senior Member
95BlueBomber's Avatar
Send a message via AIM to 95BlueBomber
Seems close to me. I tuned a 2000 six speed to 321rwhp and it was BONE stock. Who was doing the tuning?
95BlueBomber is offline   Reply With Quote
Old 05-11-2009, 10:46 PM   #5
Vette N It
CF Senior Member
Vette N It's Avatar
Quote:
IPS Motorsports here in Columbus, OH. I work with Eric and he has been great to work with so far. I don't want to get him in trouble, but they had 17 cars in to dyno on Saturday and he still CALLED ME to say come on down I'll do one more. By the time mine was done he was the only IPS employee left in the shop. He didn't have a key to the bosses office to process my payment so he said to just go ahead and leave and he would call me Monday (today) and take the CC info over the phone. I was shocked, I mean who does that?
I was just looking for opinions because I see so many 290 - 300 rwhp bone stock cars out there, and 40 - 50HP more seems doable with LT's, Blackwing and exhaust, but on the high side.
Old 05-12-2009, 11:03 PM   #6
phils C5 vette
CF Senior Member
phils C5 vette's Avatar
your numbers are right on par
The exhaust manifolds dont do a bad job on these cars. Now after you add a cam to those headers, you'll really start having fun with the car.
__________________
www.TampaTuning.com
813-727-8720
Tuned by Tampa Tuning
[SIZE="5"]451.1 RWHP@ 5900 432.8 RWTQ@ 4900
phils C5 vette is offline   Reply With Quote
Old 05-14-2009, 11:18 PM   #7
tblu92
CF Senior Member
tblu92's Avatar
Seems right to me as well Lt's are usually good for 20 RWHP with tuning and you got 17-----You didn't say if you had it tuned again after the LT's--which is a must to get the best performance--
tblu92 is offline   Reply With Quote
Reload this Page Do these numbers look right?
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
AFR 210 RR, do/did yours look like these? LD85 C4 Tech/Performance 98 12-21-2003 12:24 AM
Drag strip - do these numbers add up to you? LT-4 CE C4 Tech/Performance 10 07-21-2003 12:06 PM
A/F Ratio Question: Do these numbers look good? TIMSPEED C4 Tech/Performance 9 06-17-2003 05:47 PM
Compression test results...do these indicate worn rings? ladyinblack C4 Tech/Performance 13 11-29-2001 04:20 AM
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
