Corvette Forum
Go Back   Corvette Forum > C5 Corvettes, 1997 - 2004 > C5 Scan & Tune
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
C5 Scan & Tune
Corvette Onboard Diagnostics, Service Advice, Dyno Tuning, Fuel Management, Tuning Software, LS1 Edit, AutoTap, Diablo
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 05-09-2009, 06:32 PM   #1
hotparts
CF Senior Member
hotparts's Avatar
Default collaped lifter on a 402 with YSI
Today we hat a turn on the german autobahn with a new 402 with an YSI charger.
First we had a pull with the 6 th gear from 2000 to 5000 rpm and afterwards only second and third gear to 6000 rpm (15 PSI on 6000).
Then we cruised some minutes only at 3000 rpm and suddenly there came a terrible noise.
We took off the valve covers and saw that one pusrod was a little bit lower than the others (but the roller rocker was fixed perfect).
Now we think that the lifter collaped.
Did you ever had such a problem?
Do you use mechanic or other lifters for this configuration?
402 Callies stroker with Mallet pistons and AFR 225 heads +++
only one collaped lifter
hotparts is offline   Reply With Quote
Reload this Page collaped lifter on a 402 with YSI
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
