Corvette Forum
Go Back   Corvette Forum > C5 Corvettes, 1997 - 2004 > C5 Scan & Tune
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
C5 Scan & Tune
Corvette Onboard Diagnostics, Service Advice, Dyno Tuning, Fuel Management, Tuning Software, LS1 Edit, AutoTap, Diablo
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 05-04-2009, 03:10 PM   #1
Fast one
CF Senior Member
Default How can I wire an LC-1 to replace the DS stock NB O2?
Does anyone have a wiring diagram on how to wire an LC-1 so that it will function as a narrow band O2 and replace the stock O2 sensor? I want to use the wideband output for tuning.
Fast one is offline   Reply With Quote
Old 05-05-2009, 10:00 AM   #2
AlwaysInBoost
CF Senior Member
AlwaysInBoost's Avatar
the LC1 should have two analog outputs. analog one outputs a signal the simulates the stock narrow band o2 sensor, I forget the exact voltage but its something like 1.1v - .1v. thats the one you want to use to trick the ECU into thinking there is a narrowband o2 still hooked up.
The second analog two outputs the wideband signal in 0-5v. thats the one you want to hook up to your datalogger or ECU. HTH
AlwaysInBoost is offline   Reply With Quote
Old 05-06-2009, 11:36 AM   #3
Fast one
CF Senior Member
Can the stock O2 heater +12v ign and ground wires (brown and black) power the LC-1 and if so should the sensor return (tan/white) wire connect to the black ground wire?
Reload this Page How can I wire an LC-1 to replace the DS stock NB O2?
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
