Corvette Forum
Go Back   Corvette Forum > C5 Corvettes, 1997 - 2004 > C5 Scan & Tune
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
C5 Scan & Tune
Corvette Onboard Diagnostics, Service Advice, Dyno Tuning, Fuel Management, Tuning Software, LS1 Edit, AutoTap, Diablo
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 05-01-2009, 07:39 PM   #1
KenShores
CF Senior Member
Default tuners ????
Reading on the forum here, I seen talk of people using tuner's to set up their cars. I've been away from "race cars" for a long time now. We used to break out the wrenches and screw drivers to set timing and fuel mixtures and such. Now it's the tuners.
So what's a good tuner to get so that I can store and modify different "tunes" and that is easy to read and understand? What is out there that would help me understand what I'm doing and what affects what when I do it? Is it all trial and error?
I got standard C5 auto LS1.
Of course I've seen the chips and stuff to make 500+ HP and get 30 MPH. Why anyone wants to drive a 500 HP car to get 30 MPH is beyond me. I want horsepower, buying the gas is necessary.
Is there tuners that can download setups from others (tuners), computers, other cars, and possibly from folks like us on the net? When mod's are made, intake, exhaust, etc. is re-tuning necessary, and what types of things are re-tuned?
Thanks for any input on this. There seems to be many products available and I would like to get one that seems to be proven by the folks here.
I have read the threads here after posting this in the wrong section/forum. I like the idea of trying tunes from others that have done this before, kind of trusting, but want the ablity to load, save, edit files/tunes and that sort of thing to a laptop.
So what tuners can do these sorts of things or at all?
Thanks for all inputs
KenShores is offline   Reply With Quote
Old 05-03-2009, 02:01 PM   #2
Brian@RPT
Supporting Vendor
Brian@RPT's Avatar
To this day, I use HP Tuners VCM Suite that includes the editor and scanner. The two programs work with each other making tuning much simplier. The editor allows you to tune 100's or prarameters and with options like custom operating systems and real time tuning, this is an excellent choice for VCM tuning. The cable also has an external input connection to allow a wideband O2 (or any other 0-5V sensor) to be seamlessly intergrated to the scanner. As far as using other people tunes, I would not advise that. Exveryone has different parts and skill levels. Looking at another tuning can be used a reference. The best thing is making small changes and learning how that effects the car. You will find tuning to be addicting......at least I have. BTW, ask lots of questions
Brian@RPT is offline   Reply With Quote
Old 05-04-2009, 01:09 PM   #3
BLOWNBLUEZ06
BLOWNBLUEZ06's Avatar
There is much to learn by using any decent tuning software. Sounds like you have a good understanding of the needs of an engine. The tuning of EFI cars is in 3 dimensions and is therefore possible to tune a car to almost perfection from every angle, but also makes it possible to ruin it. I too prefer and use HPtuners. They have a forum with support available at http://www.hptuners.com/forum . There are "stickys" at the top of the page. Before you ask questions, you should enter the "FAQ" and "getting started" sections. Read and try to understand. Then go to the Gen3 section and read about tuning issues and solutions. I have some nice tutorials and notes that I have copied and in some cases created or modified so I may better understand the processes. You're welcome to a copy of these items. PM me if you're interested and I can e-mail them to you.
__________________
Dallas Performance LSX434, A&A Ysi, ram air intercooler, 1000cc injectors and custom cam from Dallas Performance, Nitrous Outlet direct port ZR1-TR6060 by the great RKT56.com aka: RagtopWS6 ,RPM C6Z Quaife Diff, A few tricks learned from the great Arun @CCP and Ed Hutchings. 1057RWHP on blower and 1250RWHP on the nitrous. Assembled and tuned by yours truly.
-Scott Evans
I spend my money on Car Parts and Race Gas... The Rest I waste...
BLOWNBLUEZ06 is offline   Reply With Quote
Old 05-04-2009, 01:47 PM   #4
tblu92
CF Senior Member
tblu92's Avatar
It's not all quite that simple---You need old school knowledge (which seems that you have) and the ability to manuver around a computer's workings--
A short lesson--There are 2 basic froms of operation with these ECM's--closed loop and open loop Power Enrichment--Most all your part throttle driving is done in closed loop which relys on the 02 sensors to adjust the fuel at a stoich 14.68-1---Thers is no better efficient fuel usage--period-- The ECM has the ability to make it's own corrections to the fuel to get 14.68 when things change like altitude ,air temp density etc---However when you floor it the engine goes into open loop power enrichment--Here the stoich 14.68 and the 02's are out the window and the ECM commands fuel to whatever is in its PE program--
From the factory the engine are all pig rich--otherwise some people would blow them up in the 1st week--Stock rich programs help save a motor from abuse--But in here lies the ability to make adjustments to the AFR to get more HP for the "sane " driver--believe me--you can easily melt a motor down by leaning it out too much with tuning-A stock PE is usually like 11.0 ---but the most HP is created at around 12.9
--This is just the fuel tuning---basically the same senario goes for the timing as well---
Fuel and Timing--The old school knowledge still is the same--only the way you change them is different--
A stockish type motor with bolt ons can usually self adjust the AFR in closed loop as the 02's rule there --But the PE fuel will change--most often goes leaner and must be checked
A hds/cam type motor will often take much more work--the ECM can't corrrect itself enough in closed loop --Fuel will be close but may take some minor changes to not throw codes--the biggest task will be to fix things like idle-surging,dying
And again in PE mode it must be checked becuase of the increased airflow it usually leans them down-
These are the basics--There are about 450 tables in the ECM that can be adjusted-There are many muluiplier factors and bulit in add on or subtraction tables-The SPARK file has for example about 55 tables alone !!!
Hope this helps some--would be glad to answer any questions--Again this is a one paragraph basic view of what's going on--
tblu92 is offline   Reply With Quote
Reload this Page tuners ????
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
Too much power around town xtream1 C5 Forced Induction/Nitrous 50 01-21-2005 12:58 AM
[VIDEO] South Carolina -TUNERS SHOOTOUT - LS1/LS6 Spectacular!!! vstella C5 Tech 66 03-12-2004 09:21 PM
The truth about tuners! MagRed01Atty C5 Scan & Tune 16 01-28-2004 09:03 PM
Which tuners offer a 368 package? Who's is best value? PaceThis C4 ZR-1 Discussion 46 09-11-2003 07:21 PM
Texas tuners. . . MTI, LGMotorsports, etc. Pigface1 C5 Tech 59 05-16-2002 03:26 AM
For the Tuners out there that want to help a young guy out! wheresmyz C5 Tech 63 04-27-2002 07:07 PM
Does the Powerloader "lock out" PCM reprogramming from other tuners? smosier C5 Tech 39 09-13-2001 12:07 AM
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
