Corvette Forum
Go Back   Corvette Forum > C5 Corvettes, 1997 - 2004 > C5 Scan & Tune
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
C5 Scan & Tune
Corvette Onboard Diagnostics, Service Advice, Dyno Tuning, Fuel Management, Tuning Software, LS1 Edit, AutoTap, Diablo
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 04-29-2009, 12:36 AM   #1
95BLKVette
CF Senior Member
95BLKVette's Avatar
Default Missfire @ Idle in Closed Loop Only
99 Corvette Convertible Stock LS-1 with 71,800 miles
Idles fine up to 189F. As soon as water temp gets to 190F it starts missing at idle like crazy.
Initially had Map code and found the Map sensor had come unplugged?? Plugged it back in and it worked fine for about 2 days, then it started missing again. Changed the Map Sensor and it still does it.
Sets the following codes after clearing codes:
10 PCM:
P300H History Missfire
B0RFA:
U1064H History No Signal BCM Body Control Module
U1096H History No Signal IPC Instrument Panel Control
U1016H History No Signal PCM Engoine Control Module
No Other Codes
Removed connectors on PCM and BCM and replugged...all clean and tight. PCM connector bolts torqued to specs.
Checked from frame rail ground packs all clean.
Think it may be an oxygen sensor with an intermittent therfore not setting O2 sensor codes, but I only have a tech 1 for my 95 and am just checking codes via the DIC on this 99.
Any ideas?
Stumped!
__________________
10/99 95 Blk LT-1 Cpe 383 LT1, J&E Forged Pistons, Eagle Forged SIR Rods GM Hot Cam,1.6 RR, Ported Heads, 30# Injectors, PaceSetter Shorty Hdrs, 3" SS Exh, LT1-Edit, Accel 300+, 160 Thermo, Tbody Bypass, LT-4 Knock, 9" ProTorque 3,000, 129K mls (5/07) Self-rebuilt 4L60E
12/30/04 99 Torch Red Vert, Tan Int, Blk Top, Auto, 21K mls (5/07 58K mls). Twlt Sent, HUD, Pwr Lthr Sport Sts, Memry, CV Real Time Dmpg, Pwr Tele Str Whl, 12 CD Chngr, Dual Clmt Cntrl, Active Hdlg, Trctn Cntrl, Fog Lmps.
95BLKVette is offline   Reply With Quote
Old 04-29-2009, 10:01 AM   #2
jedblanks
CF Senior Member
jedblanks's Avatar
Do you know anyone with realtime datalogging equipment (aka HP Tuners?)
You can watch the O2 response times real time to tell if they are bad.
jedblanks is offline   Reply With Quote
Old 04-29-2009, 05:05 PM   #3
95BLKVette
CF Senior Member
95BLKVette's Avatar
Unfortunately I have LT-1 edit and also a Tech 1 scanner for my 95, but don't have the HP or LS1edit for this 99 and don't really know anyone close by.
I'm going to see if LS-1's web page offers the software for the real time viewing like they do for LT1-edit as I think the OBDII cables are the same for both.
Reload this Page Missfire @ Idle in Closed Loop Only
Tags
c5, closed, corvette, fire, loop, miss, missfire
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
