Corvette Forum
Go Back   Corvette Forum > C5 Corvettes, 1997 - 2004 > C5 Scan & Tune
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
C5 Scan & Tune
Corvette Onboard Diagnostics, Service Advice, Dyno Tuning, Fuel Management, Tuning Software, LS1 Edit, AutoTap, Diablo
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 04-22-2009, 10:15 AM   #1
Fastbird
Former Sponsor
Fastbird's Avatar
Send a message via AIM to Fastbird
Default Out of Whack Tune root cause of Noticable Engine Vibe??
Just wondering if an out of whack tune could be the cause of a pretty noticable engine vibration. Idle on up it's present, driving or free revving. At about 1800 RPM's it actually begins to wobble the car on the jackstands. You can hear it misfiring a bit at idle due to the oil it's burning off from what got into the turbo's, so I'm leaning this direction but I thought I'd ask the experts.
Engine is a fresh 377 from TSP, clutch is a zero balance OZ700, has a powerbond underdrive pulley that was fine prior. I do have a squeaking pulley up front though, not sure which one at this point.
Fastbird is offline   Reply With Quote
Old 04-22-2009, 03:23 PM   #2
Billf6531
CF Senior Member
Billf6531's Avatar
Absolutely if it's lean and beyond the capability of the PCM to compensate. Log it and see.
__________________
Best regards,
Bill
Calgary, Alberta, Canada
2003 Quicksilver roadster , 1SB, F55, QF5, MN6, Z06 Ti catback, 2 cat H-pipe & air lid, Euro red/amber tails, Vette Net, and HP Tuners s/w - available for free to anyone in Calgary
Billf6531 is offline   Reply With Quote
Old 04-22-2009, 03:26 PM   #3
slothy
CF Senior Member
slothy's Avatar
Send a message via AIM to slothy Send a message via Yahoo to slothy
wouldnt a code pop up?
slothy is offline   Reply With Quote
Old 04-22-2009, 03:50 PM   #4
Fastbird
Former Sponsor
Fastbird's Avatar
Quote:
No capability to log (still living in the LTx era ). Will be possibly seeing my tuner on Saturday, he said if he's in bring it by and he'll take a look at it.
Quote:
You would think, but not necessarily.
Old 04-22-2009, 04:03 PM   #5
Billf6531
CF Senior Member
Billf6531's Avatar
If it was my car, I wouldn't be driving it - unsolicited advice, I know. Ask around and see if someone can come over and throw any sort of OBDII scanner on it to check the fuel trims and timing. You've probably got a lot of time and money in that toy, and it would be foolish to damage something.
__________________
Best regards,
Bill
Old 04-22-2009, 04:11 PM   #6
Fastbird
Former Sponsor
Fastbird's Avatar
It's already been driven. The motor is actually running quite nice save for this vibration. It's idling around 16 on the wide band, a blip of the throttle will bring it down to around 13.9-15.0. It's just the vibration I'm feeling.
I'm kind of leaning towards it being tune based because it was a 2Bar SD tune that simply had some fuel removed at idle, and had the MAF and O2's turned back on. The maf was deleted for the SD tune obviously, and the O2's turned off for an open loop tune because they were laggy with the turbo's right there. But.......even in open loop starting up I'm getting the vibration.
Old 04-22-2009, 04:16 PM   #7
Billf6531
CF Senior Member
Billf6531's Avatar
Good luck, and please post your findings to help the next guy.
Old 04-22-2009, 05:05 PM   #8
Fastbird
Former Sponsor
Fastbird's Avatar
Definitely. I'm going to fire it up again tonight and see if some of the oil burnoff is getting any better and take a look at the pulleys to make sure everything is kosher there.
Old 04-22-2009, 07:36 PM   #9
vrybad
CF Senior Member
vrybad's Avatar
If you have not already, I'd throw a new set of plugs in it, too.
Could just be a misfire due to plug fouling with all that oil in the engine(provided some did get into the cylinders, too)
vrybad is offline   Reply With Quote
Old 04-23-2009, 02:27 AM   #10
Fastbird
Former Sponsor
Fastbird's Avatar
It's got a VERY young set of Autolite 605's, but (and before I read this post too) while I was at work at Autozone tonight I picked up another set to swap in so I can get a good read on the ones that are in there. I believe the ones in the car only have maybe 20 minutes of run time on them.
Old 04-23-2009, 11:22 AM   #11
vrybad
CF Senior Member
vrybad's Avatar
I agree, it is a cheap possible remedy.
Old 04-24-2009, 12:10 AM   #12
Fastbird
Former Sponsor
Fastbird's Avatar
Quite sure it's NOT the tune after driving it around the block today. Consider this thread a dud.
Old 04-24-2009, 12:17 AM   #13
Billf6531
CF Senior Member
Billf6531's Avatar
Sounds mechanical then - broken valve spring or wrong preload?
Old 04-24-2009, 12:25 AM   #14
Fastbird
Former Sponsor
Fastbird's Avatar
No, I've got zero valvetrain noise at all. Motor isn't acting like it's got too much load on the rockers either.
Old 04-24-2009, 12:49 AM   #15
Billf6531
CF Senior Member
Billf6531's Avatar
Okay, what did you find that explains the problem you identified?
Old 04-24-2009, 01:01 AM   #16
Fastbird
Former Sponsor
Fastbird's Avatar
It just feels absolutely mechanical. It's too sharp and RPM dependent to be a tune issue. The vibration progressed right along with the RPM's all the way up to 4000 RPM today (very easy ride up mind you) increasing in intensity along with RPM increase, and you could feel it through the steering wheel, shifter, chassis, everything. Pop to neutral and it subdues as the RPm's drop, engine braking was slower as the RPM's were dropping slower. Due to the tune the idle likes to drop to 500ish when you suddenly let off the gas, and it was almost imperceptible when it was down that low.
Now, I will say that the car definitely needs tuning and is most certainly running lean as reported back by my wide band. The exhaust waters the eyes in a heartbeat if you're behind it. But I don't think it's possibly that it's tune related given the way it acts.
Old 04-24-2009, 08:45 AM   #17
vrybad
CF Senior Member
vrybad's Avatar
Man, best of luck finding the issue.
Hopefully you can iron it out, and it turns out to be something simple.
You put a lot of work into that beast, it's never pleasant to have issues.
Old 04-24-2009, 09:28 PM   #18
Today's problem is..
CF Senior Member
Cruise-In VI Veteran
St. Jude Donor '09
Today's problem is..'s Avatar
I know this sounds like a stupid suggestion, but I had a customer come in 3 days ago with a BMW 530i, hellacious vibration from idle up to about 3500 rpm, said it had been at 4 shops, engine/trans mounts replaced, vibration dampener replaced, full tune up w/ coils and plugs, all the usual stuff.
The car had been double filled with oil at a Jiffy Lube and had 14 qts of oil in it, causing the crank to whip in the oil and cause the vibration. It took me a while to find it as I dont normally check the oil level for an engine vibration, but I will from now on.
Good luck with finding it and hopefully it isnt an internal balance issue.
Today's problem is.. is offline   Reply With Quote
Old 04-25-2009, 12:46 AM   #19
Fastbird
Former Sponsor
Fastbird's Avatar
That's EXACTLY why I just changed the oil yesterday, put 5.5 quarts of Valvoline VR1 into it (ls2/3 pan conversion). No change.
I am left to try a couple of things tomorrow. I'm going to pull the belts and see if it's perhaps an out of whack accessory given I've got a squeaker. Then when that gets me nowhere I"m going to see if it might be something that can be attached or removed from the flywheel (counterweight). If nothing there........I'm going to look at the motor mounts although with the sharpness of the vibes I doubt it's the cause.
Old 04-25-2009, 01:43 AM   #20
Fastbird
Former Sponsor
Fastbird's Avatar
Holy jeebus I think I found the problem. I was digging around and came across the following thread from 2007 with some pics still up: http://forums.corvetteforum.com/c5-t...s2-gotcha.html
So......I hop out to the car and pull the #2 plug wire. Lo and behold, look what I find:
I think this DEFINITELY could be the root cause of the issues. A not-completely bolted down motor with the block riding on the mount frame. Going to drain and pull the A/C compressor tomorrow and try to fix it.
Could someone do me a favor though and hop out to the garage and see if your mount is sitting flush or not?? Just for verification?
Reload this Page Out of Whack Tune root cause of Noticable Engine Vibe??
Tags
c5, corvette, engine, vibes
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
