I worked with the settings for a while, logged data, checked LTFTs and made adjustments.
Contacted a moderator on the diablosport forum and emailed my tune and they emailed one back with my mods in it. Re-checked the LTFTs and things and it seems perfect and feels like it driving too.
How did u logged data? do u have new predator or old ver 2.13 ? i already bought serial -Usb cable, so need to conect laptop and see what happens.
I just got predator today, and already installed 160 stat, change coolant, change oil too.
already adjusted fAN settings, adjusted LTFT's added fuel was running lean, disable rear O2's, set COT to 1200. At wot both LTFT's are at 0 (zero) which is very good, but its fluctuating at cruise tho, need to drive another 20-30 miles to observe than will contact lew at diablo.
if he was able to save data logs, then he has to have a new one on a 9rXX revision... the older 2.xx revisions can not save logs... you can still monitor the data live on the screen while you drive, but you can't save data logs.
__________________
2006 Monte Carlo SS -- CAI, Poly mounts, STB's, FM Super 40's, Custom DiabLew Tune! Email: 06MonteSS@diablewtune.com
Good forum over there too.
Good to hear! Congrats!
Hey, where can I get the manual for the Predator? I'd like a hard copy so that I can read it in my spare time rather than scrolling through the stickies/threads. (Thanks)
They have a new version out? I suppose us with the older version (1 year old) are out of luck? No chance to upgrade?
if you have an old model, which would be on a 2.xx revision number, then yes, you can send it in to get it upgraded to the new hardware - which will enable you to save data logs, get downloadable revision updates from their site, etc etc.
will cost ya $99... you'd have to restore the original backup to your car first, then ship it back to them...
