Corvette Forum
Go Back   Corvette Forum > C5 Corvettes, 1997 - 2004 > C5 Scan & Tune
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
C5 Scan & Tune
Corvette Onboard Diagnostics, Service Advice, Dyno Tuning, Fuel Management, Tuning Software, LS1 Edit, AutoTap, Diablo
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 04-18-2009, 05:49 PM   #1
Chevy-SS
CF Senior Member
Chevy-SS's Avatar
Default Easiest way to adjust fan settings?
I did a Chuck CoW tune and I ended up deciding to keep the factory stat. Now the fan runs all the time after the engine warms up to 180* +/-. Is there any easy way to adjust the fan setting without sending the whole computer back to Chuck?
Everything else is fine. I just want to set the fan switch back to stock specs.
Many thanks for any suggestions.
Chevy-SS is offline   Reply With Quote
Old 04-18-2009, 11:53 PM   #2
briann510
CF Senior Member
Just call around and find a tuner that will set it for you. Takes 5 minutes to download your tune, change it and upload it back with new fan settings. Someone should do it for you for very little cost just to be nice.
briann510 is offline   Reply With Quote
Old 04-19-2009, 04:10 PM   #3
Brian@RPT
Supporting Vendor
Brian@RPT's Avatar
If the VCM is locked, you will need to send it back.
Brian@RPT is offline   Reply With Quote
Old 04-19-2009, 05:18 PM   #4
briann510
CF Senior Member
Quote:
Yea thats gonna suck if they locked it...Find out from them first if they did lick the tune.
Old 04-20-2009, 04:27 PM   #5
Chevy-SS
CF Senior Member
Chevy-SS's Avatar
Quote:
Thanks, I was thinking of doing this........
Old 04-21-2009, 11:19 PM   #6
minitech
CF Senior Member
minitech's Avatar
And if it is costly or difficult to get the tune changed just go ahead and change the stat for $35.00
minitech is offline   Reply With Quote
Old 04-22-2009, 09:41 AM   #7
Chevy-SS
CF Senior Member
Chevy-SS's Avatar
Quote:
I already have the 160* stat, which was supplied by Chuck CoW. When I use it, I can detect a tiny amount of piston rap. The piston rap only goes away completely when the engine is about 180*. Thus I want to use the factory stat as long as I own this car........
Reload this Page Easiest way to adjust fan settings?
Tags
adjust, corvette, fan, switch
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
