Corvette Forum
Go Back   Corvette Forum > C5 Corvettes, 1997 - 2004 > C5 Scan & Tune
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
C5 Scan & Tune
Corvette Onboard Diagnostics, Service Advice, Dyno Tuning, Fuel Management, Tuning Software, LS1 Edit, AutoTap, Diablo
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 04-15-2009, 12:51 AM   #1
wannagofast
CF Senior Member
wannagofast's Avatar
Default What Air Fuel Ratio you running under boost and how much boost?
I have a question for some of you guys that are tuning your own car, Under boost at WOT what is a good and safe AFR to run??
Rob
wannagofast is offline   Reply With Quote
Old 04-15-2009, 03:54 AM   #2
Billf6531
CF Senior Member
Billf6531's Avatar
12 with meth injection.
Billf6531 is offline   Reply With Quote
Old 04-16-2009, 12:36 AM   #3
TurboBerserker
CF Senior Member
TurboBerserker's Avatar
I run 11.4 at WOT regardless of the boost level. You'll get more power out of 11.4 and more timing than you will leaning it out to 12 (you'll have to drop timing to get it that lean).
Running meth injection just means you should retune to hit your AFR target. If you are running enough meth to make a difference in the AFR, it will pretty much bog you and you'll have to lean out the cells where your meth is flowing.
I run a progressive meth controller which allows me to only run meth when I'm really into the throttle and running high boost. Even so, my boost VE table is really scary looking if you don't know I'm running three meth nozzles lol.
__________________
Hello, my name is Erik and I am a horsepower addict...
Vice1: 03 SSS
408, Front mount TT, FLT Level 5 4L80E, TEA stgIII 6.0L heads, 238/239 115lsa 112icl +3 adv cam, FMIC, Alky Control meth Inj.
Vice2: 97 C5 (10.5:1 LSX 427, MM12 driveline, 13" snowplow blade )
Vice3: 08 TBSS AWD (stock )
TurboBerserker is offline   Reply With Quote
Old 04-16-2009, 12:42 AM   #4
purrvert
CF Senior Member
purrvert's Avatar
11.5 @ 7psi, I believe anything under 12 should be safe.
purrvert is online now   Reply With Quote
Old 04-16-2009, 03:06 PM   #5
95BlueBomber
CF Senior Member
95BlueBomber's Avatar
Send a message via AIM to 95BlueBomber
I run 11:1 because my methanol kit is turned all the way up. It gives me the ability to back off my AFR with the turn of a knob if I want to make a bit more power.
95BlueBomber is offline   Reply With Quote
Reload this Page What Air Fuel Ratio you running under boost and how much boost?
Tags
105, 1051, af, afr, air, airfuel, boost, corvette, fuel, meth, part, ratio, running, safe, throttle
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
93 oct only in the new Z06 hlv C6 Z06 Discussion 49 06-10-2005 03:09 PM
Does increasing boost mean changing cam? blu00rdstr C5 Forced Induction/Nitrous 11 01-23-2005 07:05 PM
What does detonation sound like? BLOWN IN NC C5 Forced Induction/Nitrous 13 05-19-2003 10:04 AM
Merlin777 – A Sneak Preview Merlin522 C3 Tech/Performance 80 07-12-2002 07:41 PM
Want to build a C4 for top end.... NosLaser C4 Tech/Performance 46 03-17-2002 12:33 AM
Anyone else use Toluene as a Octane Boost? SportClips C5 Tech 10 01-17-2002 02:39 PM
What would be your Ultimate Dream Small Block? John Dirks C3 Tech/Performance 23 09-10-2001 11:00 AM
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
