C5 Scan & Tune Corvette Onboard Diagnostics, Service Advice, Dyno Tuning, Fuel Management, Tuning Software, LS1 Edit, AutoTap, Diablo
Sponsored by: Kraken
PCM...Code P0420
Old 03-01-2008, 02:57 PM
6SPD98
6SPD98's Avatar
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15-'16-'17-'18- '19
Default PCM...Code P0420
Got a "check engine light".... 1/2 hour after I got the car inspected, lucky it didn't happen on the way to the inspection station.
Looked up the code and it says,"System Low Efficiency Bank 1"
Does this mean my car is getting as tired as I am?
Car only has 188,600 miles on it.
Old 03-01-2008, 06:46 PM
0Carmen@TheVetteDoctors
Former Vendor
Carmen@TheVetteDoctors's Avatar
Location: Amityville 2010 & 2011 NMCA Late Model EFI Champions BEST Service & the BEST prices on the EastCoast
You better take it to the doctor.
The Vette Doctor that is
& bring soup
Old 03-01-2008, 06:54 PM
mowton
mowton's Avatar
Old 03-01-2008, 07:49 PM
Mr. Lucky
Mr. Lucky's Avatar
St. Jude Donor '06
P0420 is a catalyst system code. Bank 1 is the driver side. The PCM compares the readings between the front O2 sensor (forward of the catalytic converter) and the rear sensor (after the cat). If it doesn't see much difference... "low efficiency." It could be just an exhaust leak, but with 188.6K on the odometer, it's probably a failed converter.
Old 03-01-2008, 09:00 PM
mowton
mowton's Avatar
Bobby, you started an epidemic....have Carmen shut off the back 02's
By the way, long time no hear. How is everything....good we hope. This are cool here, getting ready for Krissy's big day.
See ya soon
Ed
Old 03-01-2008, 10:22 PM
6SPD98
6SPD98's Avatar
Default Code....
& bring soup
Might take me a little while to get out there...doing a side job with a friend of mine.
Soup it is....
See ya soon
Ed
Everything is good. Hope to see you and Karin soon. Congrats to Krissy
Old 03-01-2008, 10:27 PM
6SPD98
6SPD98's Avatar
Default PCM Code
Thanks Mr. Lucky.....appreciate it.
To PCM...Code P0420
Quick Reply: PCM...Code P0420
