P 0420 Code any solution???
Just install a set of Headers and Hi Flow cats. Now the system is getting the "CEL" pull the codes and I am getting both P 0420 and P 0430. Any solution to solve this problem? Car is running great but hate to see "CEL" pop up.
Not unusual to see this happen with aftermarket cats. Get a local tuner to turn off the test for the rear cats for you, if it does not interfere with emissions testing in your area.
after a headers & hi flo (or no cats) install you should get a tune anyway in which the tuner can turn-off those rear 02 sensors that are now setting 420 & 430 codes, because of the increased exhaust flow...
