Corvette Forum
Go Back   Corvette Forum > C5 Corvettes, 1997 - 2004 > C5 Scan & Tune
Register Forgot Password?
Register Vendors Buy a Vette Albums Search Today's Posts Mark Forums Read FAQ TSB & RecallsGarage
Search
C5 Scan & Tune
Corvette Onboard Diagnostics, Service Advice, Dyno Tuning, Fuel Management, Tuning Software, LS1 Edit, AutoTap, Diablo
Welcome to Corvetteforum.com!
Welcome to Corvetteforum.com.
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join Corvetteforum.com today!
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 02-07-2008, 04:57 AM   #1
98 tigershark
Junior Member
Default Does anyone know what P0000 PCM DTC is?
I have recently had a chev dealer install an L/92 427 in my 98 C5 w/rpm level 5 trans and 3.42 gears. The dealer started the car with the 346 tun on the car in order to top off the tranny with fluid. I calibrated the pcm w/427 tune but noticed when I started the car no maf , cam, oil pressure sensors were plugged in so I shut the car down. There were no trouble codes at that time. About week later the dealer said they were ready again for me to tune again, but this time they drove it on the freeway for about a half hour before I got there, I read the pcm and the P000 DTC was there. I worked on the tune for 45 minutes because they said it wouldnt idle when put in gear. A crank relearn was then required. The car now idles and transitions really well from park to drive. The battery was stone dead because they left the key in. They said that they had to jump it twice prior to that. Now my voltage reads 12.9, were as before it was 13.7-9. Is the pcm damaged? The car runs great now but the DTC P0000 shows up 4 places, Mainly the PCM. Any input would be appreciated.
98 tigershark is offline   Reply With Quote
Old 02-07-2008, 12:58 PM   #2
foff667
Premium Supporting Vendor
Send a message via AIM to foff667
According to Paul at EFILive its an error in their software
Quote:
Here it is:
It looks like an error in the EFILive software.
Code P0000 is the code that the PCM sends to indicate "end of DTC list".
Please ignore it until it is fixed in the next release.
Regards
Paul
I'll assume your using efilive in this case of course.
I found that posted about 5 months ago but hopefully they've fixed it during that time.
foff667 is offline   Reply With Quote
Old 02-08-2008, 03:35 AM   #3
98 tigershark
Junior Member
Default P0000
Yes I do use EFILive.
Thank you very much! I was worried. The install has been a weird journey, But this should be it. EFILive really made the idle tuning from p/n to drive fairly easy so much that even I was surprised. The L/92 427 from SDPC is a monster. Almost unbelievable, even though the tech wasnt suppose to drive it, they were raving over it, and very impressed with EFILive and are going to purchase it for special applications. Again Thank You!
98 tigershark
Old 02-08-2008, 06:42 AM   #4
0euro@EFIAlchemy.com
CF Senior Member
Dont know about any error in EFI LIve, but if you look up OBD2 trouble code lists, P0000 is listed
P0000
No Self Diagnostic Failure Indicated
Ill be honest, ive never personaly seen that code before, but it does exist.
euro@EFIAlchemy.com is offline   Reply With Quote
Old 02-08-2008, 10:07 AM   #5
foff667
Quote:
P0000
It was posted on efilive's forum http://forum.efilive.com/archive/index.php?t-6654.html
When NO trouble codes are set the pcm will respond with the P0000 but should not show up in the scanner as to no confuse anyone into wondering why am I getting an error code & what does the P0000 DTC mean.
Old 02-08-2008, 10:38 AM   #6
CF Senior Member
Gotcha
Reload this Page Does anyone know what P0000 PCM DTC is?
Tags
0000, code, codes, corvette, diagnostic, dtc, engine, obd, obd2, obdii, p000, p0000, pcm, scan, trouble
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Powered by vBulletin® Version 3.8.7
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.2
Emails & Password Backup
