Quote:
Originally Posted by black05c6z51
okay i am looking at hp tuners setup for my c6 bu t i got a couple of questions. in order to tune correctly i need a wide band installed right. and how do i connect it to the hp tuners. if i am understandsing correct the hp tuners includes a scanner and a data logger. but most wide band i see also have a data logger or a gauge. so do i need to use both to log it and a gauge to keep an eye on it after i am done
If you get the Hptuner PRO that allows analog inputs and a popular wideband meter you will be good to go. I use an LM1 meter which has an analog output that I connect to the Hptuner Scanner analog input. You goto the Hptuner forum and do a search for scanning with a WB and you will find several threads that tell you how to do both the software and hardware aspects of the job. It sounds difficult but its really simple. If you can't find what you need PM me and I will find you the information.
INTHERED
