Corvette Forum
Go Back   Corvette Forum > C5 Corvettes, 1997 - 2004 > C5 Scan & Tune
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
C5 Scan & Tune
Corvette Onboard Diagnostics, Service Advice, Dyno Tuning, Fuel Management, Tuning Software, LS1 Edit, AutoTap, Diablo
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 06-07-2007, 06:13 AM   #1
Richard Gonzales
Junior Member
Default WOT Missing
I have a 1997 with some mild performance upgrades that brings 400 HP. The problem is excelerating at WOT up to 5500 RPM it runs great and then starts to cut out like it is lacking fuel. I can start from zero and ease it up to over 5500RPM without a miss, but with a WOT from the start I have a problem. Before I start experimenting with a higher pressure fuel pump, I would like to get your input ?
Richard Gonzales is offline   Reply With Quote
Old 06-07-2007, 01:59 PM   #2
Threed
CF Senior Member
Threed's Avatar
Location: GOCC - Rebels Without A Clue Santa Barbara, CA
One of many possibilities is a bad crankshaft sensor. It happened to a friends car. It took months to narrow it down. Installed a new sensor and everything was good.
Threed is offline   Reply With Quote
Old 06-07-2007, 09:01 PM   #3
Richard Gonzales
Junior Member
Thanks Threed, does anyone know where to look for the crankshaft sensor?
Reload this Page WOT Missing
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
383 problems ar91c4 C4 Tech/Performance 19 03-27-2005 08:33 PM
Am I missing something with these "No Cat/Gutted Cat" mods? tobijohn C4 General Discussion 21 07-02-2003 08:36 PM
I need desperate help with a slight engine idle missing problem jubee C3 Tech/Performance 18 05-10-2003 01:13 AM
New catback, now it cuts out in 1st and 2nd under WOT FELNGR8 C4 Tech/Performance 20 08-01-2002 11:51 PM
New dyno run.... even worse with WOT... GrandSportC3 C3 Tech/Performance 38 07-15-2002 11:12 AM
Found something missing on my car OrangeC4 C4 General Discussion 9 02-10-2002 12:12 AM
Any automatic C5s with mods ever hit the rev limiter in third gear when going WOT. Mopar Jimmy C5 Tech 18 08-08-2001 02:31 PM
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
