Corvette Forum
Go Back   Corvette Forum > C5 Corvettes, 1997 - 2004 > C5 Scan & Tune
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
C5 Scan & Tune
Corvette Onboard Diagnostics, Service Advice, Dyno Tuning, Fuel Management, Tuning Software, LS1 Edit, AutoTap, Diablo
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 06-04-2007, 01:11 PM   #1
dasilvaszo6
CF Senior Member
dasilvaszo6's Avatar
Default I need your imput
What do you think of o2 simulators? Just did headers and x pipe and car runs like you know what. I have a predator tuner and it doesen't help what do you think if i leave it alone and just add the sims?
dasilvaszo6 is offline   Reply With Quote
Old 06-04-2007, 02:49 PM   #2
0euro@EFIAlchemy.com
CF Senior Member
Default sims
02 Sims will not affect the way your car runs in any way, it will only prevent the deletion of the rear sims throwing a code.
I recommend you go to a wooded area, throw that predator tuner as far as you can into the woods, then go get ya a real tune from a tuner, i prefer EFI LIve
euro@EFIAlchemy.com is offline   Reply With Quote
Old 06-04-2007, 02:54 PM   #3
dasilvaszo6
CF Senior Member
Default tuner
I have a sneaking suspicion that you don't like the predator! Hmmm...
Old 06-04-2007, 03:16 PM   #4
hex
CF Senior Member
hex's Avatar
Did you make sure to connect the 2 primary sensors to the appropriate sides? If you get left and right mixed, it will run right like a cold weedeater. The secondary sensors are just cat monitors.
hex is offline   Reply With Quote
Old 06-04-2007, 04:43 PM   #5
95BlueBomber
CF Senior Member
95BlueBomber's Avatar
Send a message via AIM to 95BlueBomber
Quote:
I was at this point once, I swapped the old 02's for some 13111's and it fixed it. Hope that helps
95BlueBomber is offline   Reply With Quote
Old 06-06-2007, 04:55 PM   #6
SLPRC5
CF Senior Member
SLPRC5's Avatar
Send a message via AIM to SLPRC5
Quote:
What are the "13111". and where do you get them?
SLPRC5 is offline   Reply With Quote
Old 06-08-2007, 10:40 AM   #7
95BlueBomber
CF Senior Member
Quote:
13111 is the part number for the Z06 rear 02 sensors. They can be had at any parts store. I get mine at advance auto. They are supposed to have better heaters in them. They require changing the connector on the sensor but its worth it. My car ran bad until it was warmed up because the location of the 02 changed. The 13111 heats up quicker so it reads accurate from the start. I would think you could change the switchpoints in that fuel trim as well. It would take some tuning, I would run the car open loop and see if that clears up the problem. If so its an 02 issue.
Reload this Page I need your imput
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
Need your opinion spicycurry C4 ZR-1 Discussion 12 06-13-2005 11:09 AM
in need of some imput... mysterymachine C5 Z06 Discussion 23 11-27-2004 12:53 AM
44psi - Did I learn something new? speedy-vet C5 General 20 07-29-2004 02:25 PM
Interior Seat Question...Need Your Imput newvetter C4 General Discussion 10 10-03-2003 12:18 PM
Flood Damage Skeeter1 C5 Tech 16 07-15-2002 09:08 PM
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
