Corvette Forum
Go Back   Corvette Forum > C5 Corvettes, 1997 - 2004 > C5 Scan & Tune
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
C5 Scan & Tune
Corvette Onboard Diagnostics, Service Advice, Dyno Tuning, Fuel Management, Tuning Software, LS1 Edit, AutoTap, Diablo
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 06-01-2007, 01:25 AM   #1
00Corvette
CF Senior Member
00Corvette's Avatar
Default P0410 won't go away! Replaced check valve...
I went ahead and replaced the driver's side check valve after my 00 C5 kept throwing the P0410...any suggestions as for something else to try. Ever since I had this mail-order tune done...keeps throwing AIR, O2 and knock sensor codes!! I've also replaced both front O2's twice in the last few months and the knock sensors but it still keeps throwing the P0327...
Thanks so much,
Donnie
00Corvette is offline   Reply With Quote
Old 06-01-2007, 11:44 AM   #2
tblu92
CF Senior Member
tblu92's Avatar
Here lies the disadvantage of a mail order tune---the p0410 is a code that doesn't specify bank 1 or 2 so it is a general air system code--If nothing else was taken apart or done to your engine other than the tune--then they changed the operation of the air pump--nothing to be concerned about--you can have them turn that code off--or put the change they made back to stock---and with the p0327--it is a little tougher--again if nothing else was done they did something to the knock sensor tables or you are getting unusual spark knock--have them look at this too---I can't see where there is anything you can do without a tuner or without being able to read the program changes--
tblu92 is offline   Reply With Quote
Old 06-02-2007, 04:00 AM   #3
00Corvette
CF Senior Member
00Corvette's Avatar
Thanks man! I'll talk to the tuner and see what's up.
Donnie
Old 06-04-2007, 09:59 PM   #4
00Corvette
CF Senior Member
00Corvette's Avatar
Sir,
What do you mean by the program changes?
Thanks,
Donnie
Old 06-04-2007, 10:47 PM   #5
purrvert
CF Senior Member
purrvert's Avatar
May have turned the pump off, shortened the run time. Some folks have pulled the pump for weight and disabled the codes. Do you hear the pump when you first start the car (under left front headlight )? Should run 240 secs. Possibly one of your hoses is disconnected or damaged.
purrvert is offline   Reply With Quote
Old 07-03-2007, 12:01 PM   #6
tonykof
CF Member
tonykof's Avatar
Can anyone tell me what I need to get to disable this code? p0410..
thank
tk
tonykof is offline   Reply With Quote
Reload this Page P0410 won't go away! Replaced check valve...
Tags
air, c5, corvette, p0410, replaced, valve
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
