Corvette Forum
Go Back   Corvette Forum > C5 Corvettes, 1997 - 2004 > C5 Scan & Tune
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
C5 Scan & Tune
Corvette Onboard Diagnostics, Service Advice, Dyno Tuning, Fuel Management, Tuning Software, LS1 Edit, AutoTap, Diablo
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 05-28-2007, 10:03 AM   #1
hotparts
CF Senior Member
hotparts's Avatar
Default 40# Injectors
HI GUYS,
i got a C6 engine with 402 CI, massive cam and 225 AFR heads+ LGM headers,... in my C5.
Are 40# injeco enough or do you take bigger ones?
Best wishes
hotparts
hotparts is offline   Reply With Quote
Old 05-29-2007, 09:02 PM   #2
BLOWNZO6
Premium Supporting Vendor
BLOWNZO6's Avatar
Send a message via AIM to BLOWNZO6
40# injectors should be enough depending on how much fuel pressure you have and what kind of fuel system you have setup on the car.
__________________
2008 C6Z
1964 Coupe
EAST COAST SUPERCHARGING SALES AND TECH SUPPORT
WWW.EASTCOASTSUPERCHARGING.COM
BLOWNZO6 is offline   Reply With Quote
Old 05-30-2007, 03:22 PM   #3
hotparts
CF Senior Member
hotparts's Avatar
Hi,
thanks for your answer.
I have the normal fuel system. Should i change it?
steve
Old 05-30-2007, 04:43 PM   #4
BLOWNZO6
BLOWNZO6's Avatar
Quote:
Originally Posted by hotparts View Post
Hi,
steve
Sorry what is "normal"?
__________________
2008 C6Z
1964 Coupe
Old 05-31-2007, 05:41 AM   #5
hotparts
CF Senior Member
hotparts's Avatar
Hi,
the standard fuel system from the C5!
I only changed the injectors to the 40# ones.
Old 06-01-2007, 01:18 PM   #6
Todd157k
CF Senior Member
Support Corvetteforum!
Todd157k's Avatar
Here's a quick reference calculator for you.
Todd157k is offline   Reply With Quote
Old 06-01-2007, 11:11 PM   #7
BLOWNZO6
BLOWNZO6's Avatar
Hi,
At a minimum I would recommend running a Racetronix harness and kit on your car. The stock pump is not going to last long with much abuse.
Hope that helps.
Reload this Page 40# Injectors
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
24 lbs injectors are too lean. vettefast C4 Tech/Performance 39 07-07-2004 10:55 PM
Tested My Injectors Today..........Wow !!!!!!!!! AGENT 86 C4 Tech/Performance 24 02-18-2004 01:48 PM
I got the new Bosch injectors installed.... DarkHalo C4 Tech/Performance 75 02-11-2004 11:28 PM
Injectors.... Phil97SVT C5 Tech 15 09-13-2003 09:44 PM
Why go to Higher #/hr Fuel Injectors? Da Wiz C4 Tech/Performance 28 08-18-2003 03:27 PM
New SVO 24# Injectors installed in our 90 L98, Wow! paid4c4 C4 Tech/Performance 22 08-10-2002 09:52 PM
40 HP ADD ONS FOR Z06?? ZRWON C5 Z06 Discussion 21 12-21-2001 03:41 AM
Adding LS6 Intake and 30lb Injectors Need help. Team ZR1, Kewlbrz?? chuckster C5 Tech 52 08-20-2001 12:52 PM
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
