Corvette Forum
Go Back   Corvette Forum > C5 Corvettes, 1997 - 2004 > C5 Scan & Tune
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
C5 Scan & Tune
Corvette Onboard Diagnostics, Service Advice, Dyno Tuning, Fuel Management, Tuning Software, LS1 Edit, AutoTap, Diablo
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 05-25-2007, 06:47 PM   #1
americasfuture2k
CF Member
americasfuture2k's Avatar
XgovermentAgent
Default OBD II baud rate?
as this is called, does anyone know what the baud rate is for an obd II car? i had a 95 C4 and that is obd I. i have a 98 blazer LT now, and i am trying to make a aldl to pc device. but i dont know what the baud rate is. if anyone knows of where i can get this info for this and/or to make a data logger for obd II i would appreciate it. and maybe a way to make a programmer for it too? thanks a bunch.
americasfuture2k is offline   Reply With Quote
Old 05-26-2007, 11:41 AM   #2
Mike Mercury
CF Senior Member
Mike Mercury's Avatar
I didn't know that the OBDII port was a serial connection device.
Mike Mercury is offline   Reply With Quote
Old 05-27-2007, 12:13 AM   #3
americasfuture2k
CF Member
XgovermentAgent
it requires an aldl to pc interface. just like any obd I car.
Old 05-27-2007, 03:34 PM   #4
Mike Mercury
CF Senior Member
Quote:
cool; didn't know that
Old 07-18-2007, 03:43 PM   #5
americasfuture2k
CF Member
XgovermentAgent
bump
Old 07-22-2007, 12:08 PM   #6
americasfuture2k
CF Member
XgovermentAgent
bump
Old 07-27-2007, 04:27 AM   #7
Skunkworks
CF Senior Member
GM VPN is 10.4k, with boost function can't remmember what they call it multiply by 4.
Most scan tools operate at 10.4k.
Mike
Skunkworks is offline   Reply With Quote
Old 07-27-2007, 06:15 PM   #8
americasfuture2k
CF Member
XgovermentAgent
10.4k what? ohms? or is that the baud rate?
Old 07-27-2007, 07:24 PM   #9
Skunkworks
CF Senior Member
Baud rate 10.4 kbps... GM has perhaps the slowest serial data rate (compared to other makes) on LS1/6 PCM.
If you want additional info post what you need I might be able to help you out.
Mike
Old 07-27-2007, 08:02 PM   #10
americasfuture2k
CF Member
XgovermentAgent
oh sweet. well whatever info you feel like posting, post away. could be good for any questions i might have later on
Old 08-01-2007, 04:13 PM   #11
boosted_z06
CF Senior Member
SAE / EPA generic OBD-II is 10.4K baud
GM's VPW is 40K baud and reason a good scanner can do 40 frames a second and EPA is less then 10.
boosted_z06 is offline   Reply With Quote
Old 08-06-2007, 02:33 PM   #12
kromberg
CF Senior Member
kromberg's Avatar
Another thing that will determine/influence the baud rate is the refresh rate of the sensors. The quicker the refresh rate of the sensor, the faster is change read changes, the more expensive. Usually the cost of the sensor is exponential to the increase of the refresh rate. If the sensors have a 'slow' refresh rate, then there is no point in having a fast bus speed.
Keith
__________________
Y2K C5
Pewter Exterior / Black and Grey Interior
420 rwhp / 411 rwtq - 12.431 @ 110.79 mph - 1.8871 60' at 5800' ( Old 383 Setup )
List Of Mods
Pics of 402 Stroker with A&A F1-R Procharger Buildup
kromberg is offline   Reply With Quote
Reload this Page OBD II baud rate?
Tags
1997, baud, baudrate, c5, connection, corvette, ii, list, obd, obd2, obdii, odb, rate, rates, scanner
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
