Corvette Forum
Go Back   Corvette Forum > C5 Corvettes, 1997 - 2004 > C5 Scan & Tune
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
C5 Scan & Tune
Corvette Onboard Diagnostics, Service Advice, Dyno Tuning, Fuel Management, Tuning Software, LS1 Edit, AutoTap, Diablo
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 05-24-2007, 11:32 PM   #1
js23881
CF Senior Member
js23881's Avatar
Default Help...Rough Idle
Someone help me with this. I have just installed a 402 forged engine with D1 blower. I have 60# moltron injectors. Car runs well except for idle which is ok but generally sucks. It surges someone at idle and also at highway speed when I'm basically just cruising almost at idle rpm (really about 1500 rpm). Is it true my stock throttle body on ls6 intake probably is not giving it enough air at idle and I need to drill a small hole in it to fix?? If so can someone lead me to a thread that discusses this...thanks-
js23881 is offline   Reply With Quote
Old 05-25-2007, 12:30 AM   #2
SSpdDmon
CF Member
SSpdDmon's Avatar
Send a message via AIM to SSpdDmon
Quote:
It might be the injectors. I'd bet money you're runnig rich down low and that is partly leading to idle trouble. You may have to play with or increase the injector timing (ie the injector offsets and min pulse widths) if they aren't opening/closing as fast as the stock injectors were. Typically, 42# injectors and up begin showing idle issues when supporting injector tables are left untouched.
The other possibility is the timing. If it's bouncing all over the place when the surging occurs, that's not going to help matters much.
SSpdDmon is offline   Reply With Quote
Old 05-25-2007, 11:34 AM   #3
95BlueBomber
CF Senior Member
95BlueBomber's Avatar
Send a message via AIM to 95BlueBomber
I had this problem as well, reduced the minimum injector pulse width down to 1.003 and it took care of it. Hope that helps!
95BlueBomber is offline   Reply With Quote
Reload this Page Help...Rough Idle
Tags
c5, corvette, hot, idle, rough
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
Rough Idle! - Problem Solved And I Want To Share mph1972 C5 Tech 11 05-24-2005 06:51 PM
89 L98 rough idle, tried almost everything. GKK C4 Tech/Performance 23 05-10-2004 07:06 PM
Need Some Diagnosis Help--Rough Idle, It Almost Died This Morning. GDP C4 General Discussion 9 12-13-2002 09:18 PM
**HELP** Rough idle Then Stalls 98NYFINESTVETTE C4 Tech/Performance 16 06-03-2002 05:45 PM
Need ECM help for idle problem. Mike263 C4 Scan & Tune 10 05-13-2002 09:58 PM
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
