Quote:
Originally Posted by Beer99C5
Passenger footwell
There should be a pigtail wrapped in factory duct tape
Yellow wire is switched.
Thanks again Beer for the help! I Appreciate you bailing me out again!
Did you just use an wire tap for that?
Quote:
Originally Posted by SSpdDmon
With my LC1, I used the end of a NBO2 sensor since I was using the factory B1S1 location. Just chop the end off of an old O2 or an old O2 extension and you can wire it up. LMK if you need the wiring diagram.
Thanks SSpdDmon! I'm using the PLX, but I've got a bung welded in my pipe, so I'm not going to do NB simulation. I've got the ground, just wasn't sure where to pick up switched power. Thanks for you help though! You've also bailed me out before and I Really Appreciate it!
Thanks again Guys!
