Corvette Forum
Go Back   Corvette Forum > C5 Corvettes, 1997 - 2004 > C5 Scan & Tune
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
C5 Scan & Tune
Corvette Onboard Diagnostics, Service Advice, Dyno Tuning, Fuel Management, Tuning Software, LS1 Edit, AutoTap, Diablo
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 05-22-2007, 12:02 PM   #1
kappers
Junior Member
Default codes 1016 and P1635
1016<-- means loss of communication with the pcm
P1635<-- 5 volt reference circuit # 1
Where does a guy start on both of these codes?
kappers is offline   Reply With Quote
Old 05-22-2007, 06:43 PM   #2
tblu92
CF Senior Member
tblu92's Avatar
If the engine seems to be running fine--those are both very uncommon codes I would clear them and not worry unless they come back--
tblu92 is offline   Reply With Quote
Old 05-22-2007, 07:56 PM   #3
kappers
Junior Member
Yeah I should have posted that it will not start
Old 05-25-2007, 10:12 PM   #4
luvmy98c5
Junior Member
Hay kappers, i'm getting the same 2 codes on my 98. Were you able to resolve your issue? After i clear my codes they come back after i drive for a little bit. I have also noticed my volt meter on the dash drops to about 11 or 12 volts when i stop the car, then goes back up to about 14. I tried swapping the alternator but that didn't help. Are you experiencing anything similar to this?
luvmy98c5 is offline   Reply With Quote
Old 08-12-2007, 07:35 PM   #5
JonLT4CE
CF Senior Member
DId you ever find the P1635 code?
Thanks,
Jon
JonLT4CE is offline   Reply With Quote
Reload this Page codes 1016 and P1635
Tags
c5, p1635
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
