C5 Scan & Tune Corvette Onboard Diagnostics, Service Advice, Dyno Tuning, Fuel Management, Tuning Software, LS1 Edit, AutoTap, Diablo
Sponsored by: Kraken
Wideband install
Old 05-03-2007, 12:34 AM
PewterMetallic98
PewterMetallic98's Avatar
Default Wideband install
About to install my wideband. Wanted to see where you guys have run yours and how exactly you get it inside the car from the exhaust. Anyone have pics? Thanks in advance!!
Old 05-03-2007, 10:40 AM
minytrker
minytrker's Avatar
Do a search on here and there are pics of differnt ways everyone has ran them. There is really only 2 differnt ways most have run them for the most part. One way is up through the shifter hole in the center console and the other is through the pass floorbloard under the batt.
Old 05-03-2007, 02:19 PM
davidfarmer
Support Corvetteforum!
davidfarmer's Avatar
For temporary use, I've gone up by the PCM/Battery, then over the cowl and into the passenger door jam. For permanent use, just put holes where you need them.
Old 05-11-2007, 01:02 PM
FreddyG
FreddyG's Avatar
Patches does GREAT write ups and is METICULOUS in all of his installs. This is how I'm going to do mine when it arrives.
Patches WB02 Install with pics.................
Old 05-11-2007, 04:55 PM
FactoryRaceCar
FactoryRaceCar's Avatar
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12
^^^ Which one did you get Rob? I still have to install my LC1.
Old 05-11-2007, 07:20 PM
FreddyG
FreddyG's Avatar
Hi Nouman!
I got in on a PLX SM-AFR GB that they had on LS1Tech. I chose that one because it's Really easy for an electrically Illiterate person like me to install and it doesn't need to be free air calibrated....Not too mention the price was Way too good to pass up!
I needed to get this to freshen up my tune with the meth on. I figure that this and a dyno should do the trick!
When are you having yours put in? I saw that plate that Beer made you and it's Sweet! I might have to copy off you on that one!
Old 05-11-2007, 09:08 PM
FactoryRaceCar
Originally Posted by LuvmyC5
Hi Nouman!
Beer does awesome work. You will really love it
Old 05-11-2007, 09:40 PM
FreddyG
FreddyG's Avatar
I saw that! I've just got to figure out what I want to do there. I've got the WB02 gauge that I'd put in there, my alky control box and the attenuator **** for my windshield stereo tweeters. Quite a bit of stuff to fit behind ther, but I'm sure that it can be done.
Kind of like fitting 10 lbs of stuff in a 5 lbs. bag.
Old 05-11-2007, 10:16 PM
FactoryRaceCar
I will post pics as soon as I install mine.
Old 05-12-2007, 01:58 AM
FreddyG
FreddyG's Avatar
I'd like to see it! Thanks!
Old 05-16-2007, 01:07 PM
Bill Curlee
Bill Curlee's Avatar
Received 2,180 Likes on 1,583 Posts
CI 6,7,8,9,11 Vet
St. Jude Donor '08
I have an LC-1 and was wondering,,,,,if i removed a rear O2 sensor and installed it in there to do some tuning, will the O2 readings be the same as before the CATs as after the CATs or is it close enough as not to worry about it?
BC
Old 05-16-2007, 01:59 PM
Todd157k
Banned Scam/Spammer
Todd157k's Avatar
Bill, there was a thread on that a month or two ago. Someone tried it and said the readings were quite a bit different (don't remember how much or what direction). I'll try and find the thread but my memory is going faster than my car.
Old 05-16-2007, 11:39 PM
0EG@EnglandGreen
Supporting Tuner
EG@EnglandGreen's Avatar
Location: ================== Houston, Texas www.englandgreen.com ================== Necessary Evil™ __________
CI 6-7-8-9-10 Veteran
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12-'13-'14
BC
Bill, the WB needs to be before the cats.
Stephen
Old 05-17-2007, 07:21 AM
KBlanke
KBlanke's Avatar
What if you are not running cats? I have the LC-1 that I want to install on my track car, would the rear bung work?
Old 05-17-2007, 08:01 AM
clemsondave
clemsondave's Avatar
Anywhere after the x-pipe. That way you get data from both banks.
Old 05-17-2007, 10:42 AM
Billdog350
Billdog350's Avatar
If you find that thread, please post here! I have checked LS1Tech and this forum repeatedly and can't find any proof that after cat readings are grossly innacurate. Most say at most .5 difference at most. If you're tuning for 13.0 after cat, it will give you a safe 12.5 "true" value.
Stephen
EG, if people are installing a permanent bung I agree that before cat is ideal, but I have seen dozens of tunes done at various shops using a tailpipe sniffer (after cats) as well as post-cat 02 bungs that produced ok results. Can you add some information or experience to back up this comment that it "needs" to be before the cat? I'm very interested in how all the tuners here are doing things
here are some threads I found regarding pre/post cat WB readings.
http://www.z06vette.com/forums/archi...p/t-38077.html
http://www.innovatemotorsports.com/f...hp/t-1553.html
I have dual secondary 02 bungs on my LG Streets, but no cats, so I have been using the secondary 02 bungs rather than adding an extra bung and my self tunes are within .1-.2 of two independent dynojet sniffers.
To Wideband install
Quick Reply: Wideband install
