Corvette Forum
Go Back   Corvette Forum > C5 Corvettes, 1997 - 2004 > C5 Scan & Tune
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
C5 Scan & Tune
Corvette Onboard Diagnostics, Service Advice, Dyno Tuning, Fuel Management, Tuning Software, LS1 Edit, AutoTap, Diablo
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 03-09-2007, 01:29 PM   #1
millerls1
CF Member
Default PLEASE HELP Hypertech nightmare!!
Can anybody help!!
I just bought a hypertech for my 98. Car has been garaged for the winter. I was so excited to install the program that I went right out and hooked it up.
Halfway through the install, my car battery died!!!
the Hypertech was not able to fully load the program.
Once I jumped the car, it would not start. I have erased my stock program and now my Hypertech does not know where it left off on the previous programming.
the tuner just keeps saying "wait for communications with vehicle, turn key to "run" position."
this goes on for an hour or more with no change.
Hypertech says that I have to take my car to dealership and have the computer flashed to restore original programming. Then I have to send them my receipt from dealership along with my unit to have it unlocked.
WHAT A PAIN!!!!
Has anybody experienced this mess? Any words of advice? (besides the obvious)
My car will not even start now, just cranks. My engine diagnostic says mostly everything needs service, and 'REDUCED ENGINE POWER'
yuck.......
millerls1 is offline   Reply With Quote
Old 03-09-2007, 02:16 PM   #2
foff667
Premium Supporting Vendor
Send a message via AIM to foff667
sounds like the pcm might very well be fried...you can try the dealer route...hopefully it will work for you, but 98 pcm's are finicky about taking a S**t when the battery goes too low on a write.
foff667 is offline   Reply With Quote
Old 03-11-2007, 12:13 AM   #3
TLewis4095
CF Senior Member
Send a message via AIM to TLewis4095
PCM is most likely done as stated above. Best is to try for a used one, it should be the same year & tranny type. Good luck!
TLewis4095 is offline   Reply With Quote
Old 03-12-2007, 09:56 AM   #4
millerls1
CF Member
Default PCM/ECM Install
Is there a link or a thread anywhere on this forum for removal and installation of my ECM?
1998 Auto.
Does the 1998 have an ecm or pcm?
Old 03-12-2007, 01:36 PM   #5
TLewis4095
CF Senior Member
Its in the wheel-well of the passenger side frnt tire. Take the inner fender out and it is pretty easy to do.
Good luck!
Old 03-12-2007, 04:12 PM   #6
INTHERED
CF Senior Member
INTHERED's Avatar
Send a message via ICQ to INTHERED Send a message via AIM to INTHERED
Have you tried using the hypertech to return your car back to stock or does the error message come up before then ?
INTHERED is offline   Reply With Quote
Old 03-12-2007, 07:28 PM   #7
millerls1
CF Member
Default When I hook the hypertech back up
the unit says, "programming was interrupted"
from here it says "waiting for communications with vehicle, turn key run position, but do not crank engine"
Of course this is what I do.
It will do this for ever, I had it hooked up for over 1 hour no change.
Seems like the PCM is not taking the program.
I am just scared to take it to a dealership that is telling me $50 to flash. And them lie and say I need a new PCM.
Old 03-13-2007, 03:29 AM   #8
'VETTE PHASE
CF Senior Member
Cruise-In VIII Veteran
'VETTE PHASE's Avatar
Quote:
Good luck!
The outer part of the bracket is pretty easy to get off, one of the screws is a little hard to reach. After you get that off, the PCM slides out of the inner bracket (bolted to the frame). Being a '98, you will probably break the plastic bracket trying to get it to slide out (I used a screwdriver as a pry bar). Don't worry, it's only $12 at the dealer. Ask me how I know.
Quote:
Originally Posted by millerls1 View Post
Can anybody help!!
I had that happen to me once when I was writing mine with HP Tuners. I finally pulled the USB out of the laptop, plugged it into a different USB port and it worked. I know you can't do that, but it may mean that you just can have something else write to the PCM, like the local dealer, and maybe it's not fried.
'VETTE PHASE is offline   Reply With Quote
Old 03-13-2007, 06:30 PM   #9
millerls1
CF Member
Default Nervous
Taking car into dealer in the morning, I will post an update!
Old 03-13-2007, 07:26 PM   #10
RAMMAN
CF Senior Member
RAMMAN's Avatar
I would bet that the PCM itself is ok and it can be reprogrammed. Give us an update when its done.
__________________
ASE Certified L1 Master Automobile/ L2 Master Heavy Truck/ Master Truck Equipment Technician
Alternative Fuels Vehicle Specialist
RAMMAN is offline   Reply With Quote
Old 03-13-2007, 09:25 PM   #11
2000BSME
CF Senior Member
2000BSME's Avatar
That's the corvette gods spiting you for garaging the car all winter.
You didn't even think about the battery? Wow, sorry for that, I hope everything turns out alright.
2000BSME is offline   Reply With Quote
Old 03-14-2007, 10:04 PM   #12
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Support Corvetteforum!
Bill Curlee's Avatar
PCM looks like this!! Its the silver box. The black plactic box is the TAC Module:
Bill Curlee is offline   Reply With Quote
Old 03-15-2007, 10:11 AM   #13
millerls1
CF Member
Default Fried PCM
Yep, I fired my PCM. needed new one.
$300 later I was good to go.....
Very expensive mistake.
Now I am scared to use my Hypertech again.
Word to the wise, make sure your battery is fully charged when tuning!!
Old 03-15-2007, 04:00 PM   #14
2000BSME
CF Senior Member
2000BSME's Avatar
glad to hear that everything turned out fine, but really the mistake was purely your own. I worry about battery charge anytime my car sits for more than a month at a time. I would've thought you'd have been cognizant of that issue.
Sorry, not trying to rub it in, it just sounds like it.
Old 03-16-2007, 08:31 PM   #15
rustyguns
CF Senior Member
rustyguns's Avatar
Send a message via Yahoo to rustyguns
Default Use It !!!!!!!!!
I USE MY HYPERTECH ALL THE TIME. YOU JUST HAVE TO BE AWARE !
IF YOUR NOT AFRAID OF HAULING ASS IN A CORVETTE DO NOT BE AFRAID OF A DUMB COMPUTER!
USE IT MAN! THEY ARE REALLY GREAT!
METHODICAL IS THE MAGIC WORD!!
rustyguns is offline   Reply With Quote
Old 03-16-2007, 11:49 PM   #16
NOT2MELO
CF Senior Member
NOT2MELO's Avatar
Send a message via MSN to NOT2MELO
I am sure you have not fried the PCM its just that the TSOP on the board is most likely screwed up.
The dealer will not be able to help you other then selling you another unit.
You would have to open the PCM and pull the chip and reprogram externally and reinstall again.
Not for the average person but for a electronic technican or someone knowledgable its possible.
NOT2MELO is offline   Reply With Quote
Old 03-21-2007, 02:21 AM   #17
Turko
Junior Member
Turko's Avatar
This happened to me with my 97 ss but the only thing they did is reflash the computer. I really hated how the hypertech would take so long to down load something. I would always have my doors closed and always made sure there was nothing on before I would hook the hypertech on to the car. It seemed like that little hypertech would suck the battery dry. haha
Turko is offline   Reply With Quote
Old 03-21-2007, 02:49 AM   #18
typhoontaz
CF Senior Member
Hypertech really sucks! The same thing happened to me. I refuse to ever buy their crap again. They wouldn't even warranty their programmer because I bought it used. Have a professional do it on a dyno. Boycott Hypertech!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !!!!!
typhoontaz is offline   Reply With Quote
Old 03-22-2007, 01:04 PM   #19
mvvette97
CF Senior Member
St. Jude Donor '06-'07-'08-'09
mvvette97's Avatar
Send a message via Yahoo to mvvette97
Same exact thing happend on my 98 camaro. I also had to take the car to the dealer and get it flashed. Also sent the programmer back to get fixed. Then a year down the road it done the same thing only this time it fried the pcm. I was so mad I burnt that piece of crap programmer. Hypertech sucks
mvvette97 is offline   Reply With Quote
Old 03-31-2007, 11:36 AM   #20
codysdad
CF Senior Member
codysdad's Avatar
I've put mine in and out 20 times in my 97 K1500 and never had a problem. Dam it only takes 5-10 minutes and no big power. Just follow instructions and you won't have any problems. Makes a hell diference in my 5 speed lifted truck. Almost as fast as my vette. Not
__________________
Life's journey is not to arrive at the grave in a well preserved body; But rather to skid in sideways, totally worn out, shouting,...Holy ****....What a ride! Salinas,CA
06 Silver C6 M6- KOOKS,High flows,Vararam
396 HP 396 TK By Synergy
05 GMC K1500 lifted, chip and K&N
06 Chyrsler 300 limited
97 Chevy K1500 lifted,chiped,5 speed (sold)
99 Hayabusa 1300(sold)
34 Ford Coupe (chevy 350)sold
55 Chevy Hardtop Pro Street (10 years of work and 5 mile crash and burn)
codysdad is offline   Reply With Quote
Reload this Page PLEASE HELP Hypertech nightmare!!
Tags
back, battery, car, chip, crashed, died, hypertech, lost, oem, pcm, program, programming, restore, start, truck
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
