Corvette Forum
Go Back   Corvette Forum > C5 Corvettes, 1997 - 2004 > C5 Scan & Tune
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
C5 Scan & Tune
Corvette Onboard Diagnostics, Service Advice, Dyno Tuning, Fuel Management, Tuning Software, LS1 Edit, AutoTap, Diablo
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 03-05-2007, 10:55 AM   #1
ls1mtz
CF Senior Member
Default Millivolts = AFR
Ok, so I know that you shouldn't tune off of the millivolts because you could have a lazy or bad O2 and things could get ugly. However, I was wondering what the millivolts would read on a 03 Z06 for a 13-14 AFR?
ls1mtz is offline   Reply With Quote
Old 03-05-2007, 02:46 PM   #2
Billf6531
CF Senior Member
Billf6531's Avatar
It depends on the temperature of the sensor, and the values in the O2 Rich/Lean vs. Airflow tables. Basically the millivolt reading is telling you that you're richer or leaner than stoich. That's all a narrow band sensor knows. Get a wideband. Much cheaper than an engine rebuild.
__________________
Best regards,
Bill
Calgary, Alberta, Canada
2003 Quicksilver roadster , 1SB, F55, QF5, MN6, Z06 Ti catback, 2 cat H-pipe & air lid, Euro red/amber tails, Vette Net, and HP Tuners s/w - available for free to anyone in Calgary
Billf6531 is offline   Reply With Quote
Old 03-06-2007, 01:28 AM   #3
tblu92
CF Senior Member
tblu92's Avatar
Generally speaking a voltage around .890-.900 will yield approximately an AFR of 12.8 to 12.9 --Larger numbers are richer--smaller numbers are leaner---an AFR of 13.0 would be about .880-.870--I never have tested one near 14.0 in fear of damaging the engine but I would guess that it would be near .840-.830
tblu92 is offline   Reply With Quote
Old 03-06-2007, 10:32 AM   #4
RAMMAN
CF Senior Member
RAMMAN's Avatar
Here’s the table. But as you get to the extreme rich accuracy gets very poor.
AIR/FUEL RATIO-vs-VOLT READING
14.7/1- 0.50
14.6/1- 0.60
14.5/1- 0.70
14.2/1- 0.80
13.5/1- 0.85
13.2/1- 0.90
13.0/1- 0.92
12.5/1- 0.94
12.0/1- 0.95
__________________
ASE Certified L1 Master Automobile/ L2 Master Heavy Truck/ Master Truck Equipment Technician
Alternative Fuels Vehicle Specialist
RAMMAN is offline   Reply With Quote
Old 03-06-2007, 10:47 PM   #5
TurboLX
CF Senior Member
That data is useless without also stating a single temperature to correlate it with, like Bill said. Basically, a narrowband sensor is only good for identifying whether the engine is running rich or lean of stoich, nothing more. Attempting to determine exact AFR (off stoichiometry) from a narrowband is literally begging for broken parts.
__________________
Greg Banish
Calibrated Success, Inc.
TurboLX is offline   Reply With Quote
Old 03-07-2007, 04:01 AM   #6
EC_Tune
Supporting Vendor
Like Greg said, utterly useless.
Here's an example: Idle in Open Loop. Wideband says 14.2, narrowband says 980...
WOT: Wideband says 11.5, narrowband says 880.
Which are you going to believe?
EC_Tune is offline   Reply With Quote
Old 03-07-2007, 12:15 PM   #7
hex
CF Senior Member
hex's Avatar
14.7/1- 0.50
14.6/1- 0.60
14.5/1- 0.70
14.2/1- 0.80
13.5/1- 0.85
13.2/1- 0.90
13.0/1- 0.92
12.5/1- 0.94
12.0/1- 0.95
I don't condone it, either, but that's fairly accurate. I was tuning many years before widebands were affordable, and this is about the same I've seen.
hex is offline   Reply With Quote
Old 03-08-2007, 11:01 PM   #8
davidfarmer
CF Senior Member
Support Corvetteforum!
davidfarmer's Avatar
I always thought 450 was stoich???? Anyway, that's wide narrow-bands are worthless, they can't be counted on from car to car.
davidfarmer is offline   Reply With Quote
Old 03-09-2007, 12:43 AM   #9
TurboLX
CF Senior Member
There's a good explanation here. But these two graphs pretty much tell the narrowband output vs temp story:
Continue tuning to something other than lambda=1 with a narrowband at your own risk, folks.
__________________
Greg Banish
Old 03-11-2007, 01:12 AM   #10
leojnknsC5
CF Senior Member
leojnknsC5's Avatar
In open loop, the computer is not taking data from the O2 sensors, just the MAF, MAP, ECT, IAT, TPS.
leojnknsC5 is offline   Reply With Quote
Old 03-11-2007, 01:28 AM   #11
hex
CF Senior Member
hex's Avatar
Quote:
Pay attention.
He wanted to know a relative AFR to O2 voltage.
The oxygen sensor still outputs voltages relative to an AFR, even if it is in an open loop condition.
The difference when it is in Open loop or PE mode is that the VCM does not use the voltages for any adjustments, but they still output voltage, relative to some semblance of an AFR. That is exactly the asking gentlemen's point. I'm sure he's got the point by now that it's a better idea to use a wideband.
Reload this Page Millivolts = AFR
Tags
02, 1421, 900, afr, air, fuel, mili, milivolt, milivolts, mv, narrowband, ratio, tips, tuning, volts, wot
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
Cams - R U running a 228/588 @ 114 LSA? LeMansBlue04 C5 Tech 43 10-06-2004 11:34 PM
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
