Corvette Forum
Go Back   Corvette Forum > C5 Corvettes, 1997 - 2004 > C5 Scan & Tune
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
C5 Scan & Tune
Corvette Onboard Diagnostics, Service Advice, Dyno Tuning, Fuel Management, Tuning Software, LS1 Edit, AutoTap, Diablo
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 03-02-2007, 11:48 PM   #1
cerino2000
CF Senior Member
cerino2000's Avatar
Default What do you typically see in a scan after headers?
It seems to me that people would sometimes not add headers because they want to avoid a check engine light. I must admit, I have been one of them until I started to do some tuning and have a much better understanding of how the computer works. Now I have flipped on that view and am trying to figure out what adding headers could actually do to cause a problem. I could see if there is a routine looking to make sure that the cats heated up in a specific amount of time would cause a CEL since you move the cats back farther but what about headers making it run lean or rich. The function of CL should accomodate that, should it not? Or, is it that it changes it so much that you max out the LTFT boundaries?
cerino2000 is offline   Reply With Quote
Old 03-02-2007, 11:56 PM   #2
Zosixin
CF Senior Member
Zosixin's Avatar
I was told that after adding headers, the engine is making more hp and running lean. That is one reason why a check engine light would come on. A tune will correct this.
Zosixin is offline   Reply With Quote
Old 03-03-2007, 07:26 PM   #3
leojnknsC5
CF Senior Member
leojnknsC5's Avatar
When you add headers to an LS1, it wont throw a code cause its running lean, if it throws a code its cause the long term fuel trims exceed 14% for more than 10 minutes. The computer will compensate for the need for more fuel and keep the motor from going lean.
PO171-"Fuel trim lean", PO172-"Fuel trim rich"--these codes refer to the fuel trim settings in the computer and not the A/F ratio in the motor. Theres another code "lean fire bank one/bank two"-refers to the same condition but both banks are involved. However, the A/F ratio in the motor is adjusted by the computer to prevent an actual lean condition.
Headers aid in the evacuation of spent gases from the cylinder. By clearing out more exhaust, there is more room in the cylinder for incoming air and this will cause a lean condition until an adjustment is made to allow more fuel to be injected. The computer will adjust on its own until programming can be done.
leojnknsC5 is offline   Reply With Quote
Reload this Page What do you typically see in a scan after headers?
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
Weights, measurements, ratios, strengths, etc leaftye C5 General 239 01-18-2012 04:29 PM
Shaner TB VS. Halltech TB Z06_2002 C5 Z06 Discussion 15 03-09-2003 01:50 AM
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
