Corvette Forum
Go Back   Corvette Forum > C5 Corvettes, 1997 - 2004 > C5 Scan & Tune
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
C5 Scan & Tune
Corvette Onboard Diagnostics, Service Advice, Dyno Tuning, Fuel Management, Tuning Software, LS1 Edit, AutoTap, Diablo
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 03-02-2007, 05:26 PM   #1
04Z16
CF Senior Member
CI 3-4-5-6-7-8-9-10 Veteran
04Z16's Avatar
Default Is wideband O2 a must?
Hi,
New to tuning and just got my HP Tuners. Is the wideband O2 necessary to do just a basic tweek on the car?? I'm running an 04Z with a set of AR LT's high flow cats and a Haltech CAI.
Thanks,
Leo
04Z16 is offline   Reply With Quote
Old 03-02-2007, 08:15 PM   #2
cerino2000
CF Senior Member
cerino2000's Avatar
Without the wideband, you can't tell what the car is doing at WOT which if your tuning for WOT, you need to know.
cerino2000 is offline   Reply With Quote
Old 03-02-2007, 09:15 PM   #3
04Z16
CF Senior Member
04Z16's Avatar
So if I don't tune right off the bat for WOT and just look at and adjust the LTFT and STFT I could get by without a Wideband for the time being??
Old 03-02-2007, 09:16 PM   #4
foff667
Premium Supporting Vendor
Send a message via AIM to foff667
for fueling adjustment yes you should have access to a wideband...whether your own or a dyno's wideband.
foff667 is offline   Reply With Quote
Old 03-02-2007, 09:20 PM   #5
cerino2000
CF Senior Member
cerino2000's Avatar
One thing that you could tune would be your timing curve.
Old 03-02-2007, 09:22 PM   #6
04Z16
CF Senior Member
04Z16's Avatar
Okay so I guess it is off to find a shop who has HP Tuners and get a tune.
Old 03-02-2007, 09:25 PM   #7
04Z16
CF Senior Member
04Z16's Avatar
I just did a little ten minute run around to gather some data and see how the program works. It looked like the timing and all was pretty good. No Spark Retard, the LTFT looks strange between the two banks, about 5% difference. The STFT stays pretty close side to side.
I think it is more reading time and finding a local dyno with HP Tuners.
Old 03-02-2007, 09:50 PM   #8
jtkeller
CF Senior Member
St. Jude Donor '07
jtkeller's Avatar
I too just got hptuners and have similar mods on my z as well. I've talked with a local tuner that is well respected and he does it w/o a wideband. He's using the voltage readings from the o2 sensors that's recorded in the log files I believe. He's compared his work w and w/o a wideband and is within .1 from widebands reading. I'm going to try mine without and go from there.
jtkeller is offline   Reply With Quote
Old 03-02-2007, 09:58 PM   #9
'VETTE PHASE
CF Senior Member
Cruise-In VIII Veteran
'VETTE PHASE's Avatar
Quote:
You don't need to go find a shop. You are the shop now.
You don't have to have a wideband. I started out without one and I probably spent more money on gas than the wideband would have cost in the first place. Without a wideband, it takes much longer. With a wideband you can tune each parameter in just 3-4 runs and it will be d*mn near perfect.
This is the wideband I bought. http://www.plxdevices.com/products_SMAFR.htm $195 It doubles as my narrowband, so you don't have to weld a new bung in, just replace on of the front narrowbands that are already in there. Once you get your wideband, follow the directions below:
For VE Tuning with a wideband,
You need to:
- set the Engine/Fuel Control/OL & CL/Closed Loop Closed Loop Enable/ECT vs IAT to 284* across the board. This will put you in open loop along with setting the MAF fail freq to 0.
- on the same page as above, you want to disable LTFT
- also on this same page, in Open Loop/EQ Ratio, set all to 1.00 or I just change the ones from 140* and up to 1.00 (this will command 14.63 or stoich)
This step can be done several ways too. You can leave it as is if you want or change it to 1.13 which will command 13.0 AFR, it doesn't really matter what you are commanding, because the % error will still be the same. After going back to Closed Loop you won’t use this table anymore.
- in Engine/Fuel Control/Fuel Cutoff set DFCO enable temp to 284*
- in Engine/Fuel Control/COT, Lean Cruise set COT to disable
- in Eng. Diag/Airflow set MAF fail freq to 0 (you should also unplug the MAF if you can. If you are driving a 2001 and newer C-5 , the IAT is wired in the same plug, so you can’t unplug the MAF without doing some rewiring. They are seperate in the earlier C-5s)
- Now go log. Make sure you log VE for AFR, commanded AFR, and AFR percent error. I log first and then change the cell hits required to 25 for the percent error.
- Right click/Copy the percent error histogram
- Open Editor and use the paste special/multiply by % to the Engine/Airflow/General Airflow/Main VE/Primary table.
- Then, if you have a 1997-2000 C-5, copy the even numbered MAP lines to the secondary VE table by using the copy/paste method. Save and "write calibration only" to the PCM. Drive and see where you are.
Wash, Rinse, Repeat until your VE tables are in line. It should only take 3-4 runs.
After this, reset the MAF fail back to 14000 (leave everything else as is for now) and do the same thing for the MAF tables using MAF vs Output Freq (Hz) histograms instead of the VE histograms.
__________________
2005 Z51 Convertible MN6
- forged 404 c.i. LS2
- D1SC @ 13.5 psi
- Flip Drive
- 243
.624 on a 114 lsa
- 1 7/8" Kooks SS headers w/ 3" X-pipe, Corsa
- 707 rwhp
- Meth injection
- rear Widebody conversion
'VETTE PHASE is offline   Reply With Quote
Old 03-02-2007, 10:36 PM   #10
'VETTE PHASE
CF Senior Member
Quote:
Yea right, the guy that did my first tune was well respected too. After I got HP Tuners and looked at his tune, I had to start over from scratch. My car would hit the dreaded code 1514 (reduced power mode) at 6000 rpm. This cuts fuel to several cylinders and you can floor the gas and you get no response. I thought the motor had blown, the first time it happened. On top of this, my Injector Flow Rate was 113% at 5800 rpm, which isn't realistic because they can't flow more than 100%. Now my Injector Flow Rate is 75% at 6500 rpm and making noticeably more power. My fuel trims were not touched and the WOT was just a guess, a very rich guess. I also had 29* of timing, and running very rich at idle, because he had copied part of another guys tune who had a bigger cam in his car and required that amount of timing.
You can tune that way somewhat, but narrowbands are only accurate from ~14.0-15.0 AFR or ~.450-.550 mv. If the AFR is above or below this it is just a guess. He would have one heck of a time tuning the MAF if there was any mods to the air intake system. And WOT would be impossible to tune without a wideband because the AFR would need to be set around 13.0 AFR and the narrowbands can't read that AFR. The wideband is accurate from ~ 8.0 - 22.0 AFR.
The narrowband is very good at what it is intended to do, which is to keep your car running at stoich (14.7 AFR). If the AFR is above or below that, all it knows is that it is above or below, they don't know and don't care what the AFR is, just that it needs to tell the PCM to add or subtract fuel to get it back to 14.7. Make sense?
Tuning without a wideband can take weeks to do right. You have to change your LTFTs and then drive the car for ~ 100 miles for the car to learn the changes. Do that over and over until it is spot on. With a wideband you can do it in a day if you wanted, no less than a weekend.
Sorry if it sounds like I am ranting, but I just went throught this. I was getting so frustrated with tuning that it was getting to where it was a chore to drive my car and took the fun out of it. I tuned it with the wideband in a weekend and now I just have to tune for the fun of it.
__________________
- D1SC @ 13.5 psi
- Flip Drive
- 243
.624 on a 114 lsa
- 707 rwhp
- Meth injection
Old 03-03-2007, 04:30 PM   #11
Billf6531
CF Senior Member
Billf6531's Avatar
Run away from this guy - fast and far. If he's well respected, and doesn't use a wideband, those who respect him must be a bunch of illiterate mouth breathers. Narrow band sensors are only accurate .5 afr either side of 14.7, and only then within a narrow temperature range. You have a relatively expensive performance car, spend an hour and Google the words narrowband, wideband, and afr. Post back if you can find anyone that advocates tuning via narrowband sensors.
__________________
Best regards,
Bill
Calgary, Alberta, Canada
2003 Quicksilver roadster , 1SB, F55, QF5, MN6, Z06 Ti catback, 2 cat H-pipe & air lid, Euro red/amber tails, Vette Net, and HP Tuners s/w - available for free to anyone in Calgary
Billf6531 is offline   Reply With Quote
Old 03-03-2007, 05:10 PM   #12
cerino2000
CF Senior Member
cerino2000's Avatar
Quote:
The only way I personally would trust a tune without a wide band is if the tune was created on a car that was on a wideband and that car was identical to mine and then flashed to my car. Even then, I would want a wideband to confirm the tune.
Old 03-03-2007, 07:34 PM   #13
jtkeller
CF Senior Member
St. Jude Donor '07
jtkeller's Avatar
I've read the same about using a wideband and was equally surpised to hear that this guy wasn't using a wideband. Who knows...
Old 03-03-2007, 10:25 PM   #14
'VETTE PHASE
CF Senior Member
We know...
Old 03-03-2007, 11:57 PM   #15
JerriVette
CF Senior Member
So its important to use a wideband 02 sensor to get the proper information to tune the car.
JerriVette is offline   Reply With Quote
Old 03-05-2007, 01:29 AM   #16
tgkeller
Junior Member
Sounds like you ought to spend the extra $195 and do it right. D
tgkeller is offline   Reply With Quote
Old 03-05-2007, 09:55 AM   #17
rustyguns
CF Senior Member
rustyguns's Avatar
Send a message via Yahoo to rustyguns
Quote:
rgr that!
rustyguns is offline   Reply With Quote
Old 03-05-2007, 10:06 AM   #18
jtkeller
CF Senior Member
St. Jude Donor '07
jtkeller's Avatar
You guys act like money grows on trees!
Old 03-05-2007, 10:25 AM   #19
foff667
Your the one with the ZO6
Old 03-06-2007, 08:58 PM   #20
tgkeller
Junior Member
Quote:
...and the 2 new sets of racing wheels...and the 2 new sets of racing tires...and the new seat restraint system...and the new HP tuner thing...and the new headers...and the new shifter...and the new wife
Just kidding...I'm just jealous...Good luck on the MBA test tonight and racing this weekend...Love 'ya...Dad
Reload this Page Is wideband O2 a must?
Tags
880, band, narrow, o2, tuning, ve, wideband
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
Wideband O2 Installation Patches C5 General 24 02-19-2005 12:21 AM
did anyone use the new F.A.S.T engine mangment red L98 C4 Tech/Performance 20 10-02-2003 11:43 PM
HEY! Cheap wideband has hit the market! vvv90 C4 Forced Induction/Nitrous 40 08-07-2003 04:58 PM
Advantages of a Carb setup........ OrangeC4 C4 Tech/Performance 16 09-22-2002 06:39 AM
Wideband O2's to install instead of stock front O2's. Where to get? vette.se C5 Tech 13 07-15-2002 03:18 PM
Want to build a C4 for top end.... NosLaser C4 Tech/Performance 46 03-17-2002 12:33 AM
A piillar gauges. only found a 2-gauge pod for C5. also question about which gauges rwj383 C5 Tech 34 01-16-2002 11:17 AM
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
