Corvette Forum
Go Back   Corvette Forum > C5 Corvettes, 1997 - 2004 > C5 Scan & Tune
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
C5 Scan & Tune
Corvette Onboard Diagnostics, Service Advice, Dyno Tuning, Fuel Management, Tuning Software, LS1 Edit, AutoTap, Diablo
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 03-02-2007, 04:44 PM   #1
willseph
CF Senior Member
willseph's Avatar
Default Running untuned after cam swap?
Hey everyone, just wanted to know if I'm posing serious damage to my engine by driving my car from my garage to the tuner's shop (about 20 miles) untuned after I put the new cam in. It's a pretty mild cam, if that makes a difference. Thanks in advance!
willseph is offline   Reply With Quote
Old 03-02-2007, 04:57 PM   #2
foff667
Premium Supporting Vendor
Send a message via AIM to foff667
as long as your not changing injectors you'll probably be fine. Just keep your rpms fairly low & you should be fine as long as the cam isnt big enough to make you stall out
foff667 is offline   Reply With Quote
Old 03-02-2007, 06:30 PM   #3
Blow Torch
CF Senior Member
Blow Torch's Avatar
You don't say how "small" your cam is, but you should't have any issues. I drove a couple hundred miles after I changed my small (224) cam, and although it died every time I came to a stop (I have an auto) the only damage I did was kill one of the O2s.
Blow Torch is offline   Reply With Quote
Old 03-02-2007, 06:43 PM   #4
willseph
CF Senior Member
willseph's Avatar
the specs on the cam are 228/222 with lift in the .580 range
Old 03-02-2007, 06:50 PM   #5
Blow Torch
CF Senior Member
Blow Torch's Avatar
You should have no problem.
I didn't look at your sig for details; Is there any particular reason why you went with a reverse split cam? Planning on going FI?
Old 03-02-2007, 06:53 PM   #6
willseph
CF Senior Member
willseph's Avatar
A couple of friends went with them (one with an LS2, one with an LS6) and they had great results. I also like the stock idle that comes with it. And I would never rule out FI
Old 03-02-2007, 09:32 PM   #7
Blow Torch
CF Senior Member
Blow Torch's Avatar
Didn't mean to imply it was a bad cam. The general train of though has been to run a straight pattern or a dual pattern cam with more duration and lift on the exhaust side to help with the scavaging when running street legal exhaust. (as opposed to open headers)
I'm sure that cam will work great for you
Old 03-02-2007, 10:34 PM   #8
willseph
CF Senior Member
willseph's Avatar
I definitely didn't think you were saying anything negative about it at all. Almost everytime I tell people about the cam, they have lots of questions about it. I do plan on going with long tubes and no cats soon as well. Thanks for the advice, I'm still a noob to the more advanced theories and whatnot.
Old 03-09-2007, 09:48 PM   #9
birch64
CF Senior Member
birch64's Avatar
i'm in ur same shoes i just installed a cam and need to drive it to FLP around 40 miles away....whos doing ur tune?
birch64 is offline   Reply With Quote
Old 03-11-2007, 01:08 AM   #10
leojnknsC5
CF Senior Member
leojnknsC5's Avatar
Keep your foot out of it and it should be ok.
leojnknsC5 is offline   Reply With Quote
Old 03-14-2007, 09:35 AM   #11
MawneeC5
CF Senior Member
MawneeC5's Avatar
I drove my car around for ~8 months after a cam swap on the stock tune and even took it to the track. No issues. Its a 221/221 .575 112
Of course I've since done some other mods(boost) and now its tuned
MawneeC5 is offline   Reply With Quote
Old 03-21-2007, 12:20 AM   #12
GreyGT-C
CF Senior Member
GreyGT-C's Avatar
Send a message via AIM to GreyGT-C
i'm in the same boat... except i'll have a 2 1/2 hour drive to a tuner. Ok to drive it or should i trailer it?
was bone stock 3 days ago...
just installed Z06 heads, upper intake from a Z06, long tube headers, intake, cam (232/232 .585" 114ls) roller rockers and 50lb injectors.
advice?
Thanks!
Shannon
GreyGT-C is offline   Reply With Quote
Old 03-21-2007, 01:46 AM   #13
hex
CF Senior Member
hex's Avatar
advice?
Thanks!
Shannon
Ooh, those 50's are going to dilute the oil nicely. See if they will let you swap when you get there. Heck, they might not charge you that much to do it for you. Why do you need 50's with that setup?
hex is offline   Reply With Quote
Reload this Page Running untuned after cam swap?
Tags
228222, bad, c5, cam, cams, car, corvette, diablo, drive, heads, ls1, sport, swap, tune, untuned
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
