Corvette Forum
Go Back   Corvette Forum > C5 Corvettes, 1997 - 2004 > C5 Scan & Tune
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
C5 Scan & Tune
Corvette Onboard Diagnostics, Service Advice, Dyno Tuning, Fuel Management, Tuning Software, LS1 Edit, AutoTap, Diablo
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 02-28-2007, 08:26 AM   #1
stepuptata
CF Senior Member
stepuptata's Avatar
Default Hidden performance code???
I heard you can go through some steps on the DIC buttons and reprogram the C5 for better performance . Is this true? if so, what are the steps???
stepuptata is offline   Reply With Quote
Old 02-28-2007, 08:48 AM   #2
BudgetPlan1
CF Senior Member
St. Jude Donor '09-'10
BudgetPlan1's Avatar
Not true. You can hook up to the cars PCM via the OBDII port and use software like HP Tuners or EFI Live to reprogram PCM parameters for improved performance.
BudgetPlan1 is offline   Reply With Quote
Old 02-28-2007, 09:11 AM   #3
see5
CF Senior Member
see5's Avatar
You can only change the engine size via the secret code.
see5 is offline   Reply With Quote
Old 02-28-2007, 09:31 AM   #4
ARK 99COUP
CF Member
ARK 99COUP's Avatar
Quote:
Where does this stuff come from?
ARK 99COUP is offline   Reply With Quote
Old 02-28-2007, 10:39 AM   #5
Wah
CF Senior Member
Wah's Avatar
Quote:
Must be coming from Knight Rider. Push that "Turbo Boost" button !!!
WHOOOOOSSHH ...
Wah is offline   Reply With Quote
Old 02-28-2007, 06:03 PM   #6
stepuptata
CF Senior Member
stepuptata's Avatar
I GUESS THE GUY IS ON CRACK
Old 02-28-2007, 10:38 PM   #7
Billf6531
CF Senior Member
Billf6531's Avatar
True - just get the DIC in programming mode, enter the PFM table, and press $$$$$ - then exit. Your wallet will be empty and your Vette will be fast.
PFM - Pure F'in Magic.
__________________
Best regards,
Bill
Calgary, Alberta, Canada
2003 Quicksilver roadster , 1SB, F55, QF5, MN6, Z06 Ti catback, 2 cat H-pipe & air lid, Euro red/amber tails, Vette Net, and HP Tuners s/w - available for free to anyone in Calgary
Billf6531 is offline   Reply With Quote
Old 03-03-2007, 07:00 PM   #8
JEEP/C5
CF Senior Member
JEEP/C5's Avatar
He might be referring to the "competitive mode" with the TC. In the 01 and later you can hold down the TC button for 5 sec. or so and it put it in “competitive mode”. This mode is preferred for racing since it leave traction control off but the stability control is on which helps to keep you in your lane if things get wild. Just thought I would put my 2 cents in since this is what I thought he was referring to.
JEEP/C5 is offline   Reply With Quote
Old 03-04-2007, 08:31 AM   #9
leojnknsC5
CF Senior Member
leojnknsC5's Avatar
Who's pulling your leg?
leojnknsC5 is offline   Reply With Quote
Old 03-09-2007, 10:53 PM   #10
LT1driver
CF Senior Member
LT1driver's Avatar
I got mine with the ultra secret performance button gets me up to 5000 horsepower
LT1driver is offline   Reply With Quote
Old 03-10-2007, 02:22 AM   #11
z06nut
CF Senior Member
z06nut's Avatar
Even with the programers, the results will be minimal unless you have modded your engine.
z06nut is offline   Reply With Quote
Old 03-10-2007, 04:02 AM   #12
striper
CF Senior Member
striper's Avatar
It is so true! You also need a Tech 2, which I have. If you hook it up in the proper sequence and go into the DIC, you can access performance mode in the computer. I gained 75 rwhp! Only took three minutes.
striper is offline   Reply With Quote
Old 03-11-2007, 10:24 PM   #13
rgtkst
CF Senior Member
rgtkst's Avatar
Quote:
YOURS DIDNT WORK RIGHT. i got almost 90 by doing that the biggest part was the increased mileage that went with it. seems to have more volume to the stk bose system too
rgtkst is offline   Reply With Quote
Old 03-14-2007, 09:39 AM   #14
MawneeC5
CF Senior Member
MawneeC5's Avatar
Up, Up, Down, Down, Left, Right, Left, Right, B, A, B, A
It wont give you more power, but if you crash your car it will appear in the garage good as new the next morning.
MawneeC5 is offline   Reply With Quote
Old 03-16-2007, 01:58 AM   #15
savage1
CF Senior Member
savage1's Avatar
LMOA THAT'S FUNNY RIGHT THERE
savage1 is offline   Reply With Quote
Old 03-17-2007, 11:26 AM   #16
guiness
Junior Member
guiness's Avatar
Send a message via AIM to guiness Send a message via MSN to guiness
Quote:
OMG. I remember that code from nintendo but can't remember the game. Was it Metroid or Mikey Tyson Punchout?
guiness is offline   Reply With Quote
Old 03-17-2007, 11:40 AM   #17
Max@Cartek
Supporting Vendor
Max@Cartek's Avatar
Quote:
Contra and Life Force come to mind, maybe others. It got you 29 lives instead of 3.
It was for some of the Konami(sp?) games.
Max@Cartek is offline   Reply With Quote
Old 03-17-2007, 08:31 PM   #18
lar66BB
CF Senior Member
lar66BB's Avatar
Default performance
Quote:
This probably what you heard about. All sorts of options, you just need
to find out what is avail. and what suits your needs. Only thing I can
tell you, the more perf. you want the more it costs.
lar66BB is offline   Reply With Quote
Old 04-12-2007, 02:54 PM   #19
force fed
CF Member
you forgot select, start! there is a Deftones' song called that code too
force fed is offline   Reply With Quote
Old 04-14-2007, 12:20 AM   #20
Tony @ MPH
Supporting Vendor
Support Corvetteforum!
Tony @ MPH's Avatar
Yup, Contra for sure... A lot of Konami games also shared this code or a similar code.
Tony @ MPH is offline   Reply With Quote
Reload this Page Hidden performance code???
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
MY CAR WAS STOLEN YESTERDAY RaceCarDriver C5 Z06 Discussion 42 04-03-2010 06:16 AM
GM doesn't know how the new navigation system works!! rbl C6 Corvette General Discussion 85 10-05-2004 06:52 PM
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
