Corvette Forum
Go Back   Corvette Forum > C5 Corvettes, 1997 - 2004 > C5 Scan & Tune
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
C5 Scan & Tune
Corvette Onboard Diagnostics, Service Advice, Dyno Tuning, Fuel Management, Tuning Software, LS1 Edit, AutoTap, Diablo
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 02-25-2007, 10:50 PM   #1
stepuptata
CF Senior Member
stepuptata's Avatar
Default Dtc P0410?????, Help!!!
What is this part?, part number? Need to know where it is located and what part to buy. It s a Secondary Injeaction system malfunction. Car runs fine, just leeps throwing this DTC. Thanks for any help;.
stepuptata is offline   Reply With Quote
Old 02-26-2007, 01:25 AM   #2
Mr. Lucky
CF Senior Member
St. Jude Donor '06
Mr. Lucky's Avatar
The AIR injection system only operates for a short time at cold startup. It is strictly an emmisions thing, so it won't affect driveability.
Some people have had success spraying penetrating oil or WD40 down the hose toward the pump to loosen it up. Here is the full troubleshooting procedure.
GL!
__________________
—Bob
Looking for a place to host your Corvette website?
Contact me for special Corvette Forum member discount.
http://www.TheWholeInternet.net
Mr. Lucky is offline   Reply With Quote
Old 02-26-2007, 02:01 AM   #3
tblu92
CF Senior Member
tblu92's Avatar
I would check the AIR check valves on each side of the exhaust manifolds--They go bad quite often--as they get carboned up or moisture makes them rusty and they won't close and wil simulate an exhaust leak---I had the same code on a 01' Silverado and i replaced 1 of the valves that was not holding presure and the code quit.
tblu92 is offline   Reply With Quote
Old 02-26-2007, 07:16 AM   #4
stepuptata
CF Senior Member
stepuptata's Avatar
this all started when it got @ 0-5 degrees for a week here in cincy. It also pulls the code P1415 "bank 1" air system. Would that tell me what side of the engine. Are those the round black things on each side of the engine? Thanks for the help guys. Gotta love this site!
Old 02-26-2007, 02:59 PM   #5
tblu92
CF Senior Member
tblu92's Avatar
Yeah it is that thing about 2" long the hose goes on one end and the AIR line on the other -has about a 1" nut on it--Bank one is the driver's side---cold weather might have frozen some of the moisture in it and also probably full of rust-exhaust condensation is common to check to see it the air pimp is running--disconnect the hose on the drives side--Start it up cold then feel and see if air is being pumped--it only runs for about 2 mins at cold start--if it is running thaen more than like it is the check valve--If you have headrs--make sure the small hole in the air tubes on the primaaies is not carboned up closed
Old 02-26-2007, 10:30 PM   #6
stepuptata
CF Senior Member
stepuptata's Avatar
I'll try that tip. thanks
Reload this Page Dtc P0410?????, Help!!!
Tags
corvette, dtc, p0410
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
Help with code: P0410 calee4nyaboy C5 Tech 10 07-05-2004 04:37 PM
HELP!!! Check engine and 1416 code. What's up? RichieRich C5 Tech 10 02-08-2004 12:10 PM
CRAP, I need some help with this one! 212mike C5 Tech 16 08-27-2003 07:35 PM
HELP what's code PCM P1416 ?? imxz28 C5 Tech 11 12-19-2002 06:14 PM
Help...Code 10-P0410 and P1416, (Air System B),I do have headers installed. Supercharged C5 Tech 9 11-07-2002 11:51 PM
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
