Corvette Forum
Go Back   Corvette Forum > C5 Corvettes, 1997 - 2004 > C5 Scan & Tune
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
C5 Scan & Tune
Corvette Onboard Diagnostics, Service Advice, Dyno Tuning, Fuel Management, Tuning Software, LS1 Edit, AutoTap, Diablo
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 02-25-2007, 05:01 PM   #1
Novicetoo
CF Senior Member
Novicetoo's Avatar
Default When to tune
I am going to install a Vararam air intake system, would this require a tune? My next project will be to install a Bassani X pipe, need a tune then? Any help on this will be greatfully accepted. This is my first corvette
Novicetoo is offline   Reply With Quote
Old 02-25-2007, 05:35 PM   #2
brandtdavis
CF Senior Member
brandtdavis's Avatar
I would say not quite yet unless you are very close to a good tuner and get a good price. Your MAF sensor should meter the increased incoming air and act accordingly. I would add a few more mods before tuning.
brandtdavis is offline   Reply With Quote
Old 02-25-2007, 05:54 PM   #3
Novicetoo
CF Senior Member
Novicetoo's Avatar
Default mods
Thanks for the info.
Old 02-26-2007, 05:42 PM   #4
SLPRC5
CF Senior Member
SLPRC5's Avatar
Send a message via AIM to SLPRC5
You may get a CEL until the PCm relearns the air coming in. If you get the CEL just run the scan and reset the codes H and C. Don't worry about a tune until other mods are added i.e. cam, heads, intake and headers. my $.02
SLPRC5 is offline   Reply With Quote
Old 02-26-2007, 05:55 PM   #5
Billf6531
CF Senior Member
Billf6531's Avatar
Replacing the stock intake/filter will cause your MAF to report false air volume. Let it try and tune itself for 50 miles, or so. Then drive it and pay close attention to jerkiness in engine operation. You'll feel it through your foot. The un-smooth feeling at various points is the VE table and the MAF table fighting with one another. If you have access to a scanner, have a look at the LTFT and STFT values. You'll see what I mean.
The cost of a quality tune is approximately the same as buying HPT or EFILive and doing it yourself.
__________________
Best regards,
Bill
Calgary, Alberta, Canada
2003 Quicksilver roadster , 1SB, F55, QF5, MN6, Z06 Ti catback, 2 cat H-pipe & air lid, Euro red/amber tails, Vette Net, and HP Tuners s/w - available for free to anyone in Calgary
Billf6531 is offline   Reply With Quote
Old 02-27-2007, 02:44 AM   #6
Bluefire
CF Senior Member
Bluefire's Avatar
I installed a VaraRam and six months later I installed a Corsa Catback with X-pipe. After the VaraRam install my gas mileage took a dive to ~14 MPG. I don't know if it was the increased air flow that wasn't being compensated for or, the MAF sensor got gummed up from the initial thin coating of light oil on the new air filter (it was running lean and pulling timing). I decided that after I put on the Corsa's I would have it tuned. Many say that these mods don't do anything for performance to require a tune. I felt that I wasn't going to do any other mods in a long while that will affect the cars breathing. However, since the tune I have noticed a big increase in perceived (SOTP) power. With just these two mods, I got 325rwhp on a loaded Mustang Dyno with my stock 03 A4 and I'm back to getting ~20 MPG (Avg). The choice is yours on whether you tune it after your mods, I would. IMHO.
Bluefire is offline   Reply With Quote
Old 03-19-2007, 11:09 PM   #7
u4ick
CF Senior Member
I did just a tune as my first, "mod" and got close to 40 more rwhp I then added vara-ram and then got retuned and only gained about 5 or so then got Borla stingers cat back, and re tune for a few more I'm now at 375rwh with only the above mods.
I have a local tuner for $400 on 1st tune and $100 for retunes after mods, so I'm lucky for the convenience. But just the tune was the most increase I got, so in my opinion go there first,......if it's feasable.
D.
u4ick is offline   Reply With Quote
Old 03-20-2007, 06:26 AM   #8
EC_Tune
Supporting Vendor
You will get the "full" benefit of the mods by investing in a quality tune.
Every Vette is an individual and GM has to tune for "all conditions" mechanical and environmental. This means compromises but they all run "good" straight from Bowling Green.
Once you start stacking on the mods, a tune will show itself more and more beneficial. And as U4ick mentioned, he picked up the most just tuning from stock.
EC_Tune is offline   Reply With Quote
Reload this Page When to tune
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
Teach me how to tune my engine Ak. Mal C3 Tech/Performance 17 04-26-2005 10:31 AM
Newbie help: To tune or not to tune? hogpowr C5 Scan & Tune 69 11-22-2004 08:34 AM
When to do the first Oil Change??? Gonzo C5 Z06 Discussion 28 01-09-2004 02:04 AM
Either today was the worst day to Tune or I SUCK at LS1-Edit... chuckster C5 Tech 10 06-16-2003 12:47 AM
EGT to tune air/fuel ratio? SuperL98 C4 Scan & Tune 34 05-23-2002 08:03 PM
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
