Corvette Forum
Go Back   Corvette Forum > C5 Corvettes, 1997 - 2004 > C5 Scan & Tune
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
C5 Scan & Tune
Corvette Onboard Diagnostics, Service Advice, Dyno Tuning, Fuel Management, Tuning Software, LS1 Edit, AutoTap, Diablo
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 02-24-2007, 02:13 PM   #1
zleehw
CF Senior Member
zleehw's Avatar
Default Need mechanic assistance
I have the two following codes up ---
Service ride control --- Traction control system ---
C 1281 H
C 1286 H C
Its related to the steering
Does anyone have avail..people at dealer to look up what sensor coould be bad...?
__________________
Doug Wheeler aka Wheelz
1997 Corvette
68,000 miles and rising
6 spd, Few mods
" High Speed, Low drag "
zleehw is offline   Reply With Quote
Old 02-24-2007, 11:12 PM   #2
CorvetteTechInc
CF Senior Member
CorvetteTechInc's Avatar
From the sevice manual:
The EBTCM runs a centering routine when the vehicle speed goes above 30 Km/h (18 mph). When the vehicle reaches 30 Km/h (18 mph), the EBTCM monitors the Steering Wheel Position Sensor inputs (Phase A, Phase B and Analog voltage) to see if the steering wheel is moving. If the steering wheel is not moving for a set period of time then the EBTCM assumes the vehicle is going in a straight line. At this point, the EBTCM looks at the analog voltage signal and reads the voltage. This voltage normally around 2.5V, is then considered the center position and the digital degrees also become zero at the same time. This centering routine is necessary to compensate for wear in the steering and suspension. Wear in the steering and suspension can result in a change in the relationship between the steering wheel and the front tires when driving in a straight line. By running the centering routine the EBTCM can compensate for these changes by changing the digital and analog center position.
Conditions for Setting the DTC
DTC C1286 can be set after the centering routines completion if the bias value is ± 30° from the previous bias value.
DTC C1286 can also be set at start up if the bias value was out of range on the last ignition cycle.
Action Taken When the DTC Sets
Magna Steer® is disabled ABS/TCS remains active.
Conditions for Clearing the DTC
Condition for DTC is no longer present and scan tool clear DTC function is used.
Fifty ignition cycles have passed with no DTC(s) detected.
Diagnostic Aids
Possible causes:
-Steering wheel rotated with steering gear disconnected.
-Faulty Steering Wheel Position Sensor.
-Faulty EBTCM.
__________________
Specializing in Corvette and Muscle Car Performance & Tuning, Restoration, & Mechanical Repairs.
You want Specials! Call us!
Servicing the Mid-Hudson Valley and Surrounding Area.
Installer and Tuner for all popular SC, TT, N2O, Heads and Cam Packages, and more.
Want your Vette Overhauled, call us!
845-542-8930
Home of The FrankenSport Resto-Rod and Custom Built Corvettes!
CorvetteTechInc is offline   Reply With Quote
Reload this Page Need mechanic assistance
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
1998 C5 Won't Start Jharms C5 Tech 29 10-18-2004 06:46 PM
For Sale - 2000 Pewter coupe auto speedwaylemans C5 Corvettes for Sale 42 10-13-2004 04:09 PM
F/S 2003 Z06 Silver 2,500 Miles Chicago Chromes 2003_Z06_Chicago C5 Corvettes for Sale 33 10-11-2004 01:33 AM
Birdcage rust damage help/input needed Islander21 C1 & C2 Corvettes 25 01-14-2004 02:44 PM
Need assistance w/ hood emblem. Lost fasteners into void in hood. Rob 93ZR-1 C4 General Discussion 20 06-07-2003 03:17 AM
have to put the vette down fastrob C4 General Discussion 10 02-18-2002 01:18 AM
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
