Corvette Forum
Go Back   Corvette Forum > C5 Corvettes, 1997 - 2004 > C5 Scan & Tune
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
C5 Scan & Tune
Corvette Onboard Diagnostics, Service Advice, Dyno Tuning, Fuel Management, Tuning Software, LS1 Edit, AutoTap, Diablo
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 02-23-2007, 03:50 PM   #1
LuvmyC5
CF Senior Member
St. Jude Donor '05-'08
LuvmyC5's Avatar
Default Strange tuning question for you guys.......................
I'm having an A&A Vortech SQ blower kit installed now and I spoke to the tuner and he said that the car is going fat at 3400 rpm with 18° of timing, but when it runs with 16°'s it's much better. It's going from commanded 12:1 to 11.3:1 in this range. He said that he'll probably leave it at 16°'s and just command the AFR to 12.1:1 to make up for the lost 2°. At 3400 rpm/18°, he said that he was getting 2° kr, which I thought was weird because wouldn't getting more gas stop knock? He was still getting slight knock at 16° though.
How can changing the timing effect the AFR? It's got me stumped!
Any help would be Greatly Appreciated!
LuvmyC5 is offline   Reply With Quote
Old 02-25-2007, 03:42 AM   #2
tblu92
CF Senior Member
tblu92's Avatar
Now you have me confused--!!! but I think you said that he changed it from the 12.1 to 11.3 at 3400rpm's-- so he is going richer hoping to get rid of the 2* knock retard--which makes sense--richer fueling would get rid of some small knock--but more or less timing shouldn't change the AFR---exacty opposite more or less AFR would allow more programmed timing or not allow more programmed timing--either you mis-understod him or you wrote it down wrong--but I can't really figure out what you are trying to say--unless what i suggested is correct----
tblu92 is offline   Reply With Quote
Old 02-25-2007, 11:48 AM   #3
LuvmyC5
CF Senior Member
LuvmyC5's Avatar
Quote:
Thanks for the reply!
The only thing that he changed was timing. He put 2° in it and then the AFR changed by itself. The commanded AFR was 12:1, and fattened to 11.3:1. and still got knock. I can't figure it out because changing timing should have no effect on Commanded AFR.
Please tell me if this explanation made more sense.
Old 02-25-2007, 03:55 PM   #4
tblu92
CF Senior Member
tblu92's Avatar
Ok i think I understand what you mean----The data you are missing is the ACTUAL AFR---the commanded really dosen' mean anything--what hapens is after all the mods--unless the VE table is corrected the commanded does not match the actual anymore---On my C5 cammed vette I have to command a 12.15 in order to achieve a WOT AFR of 12.8---There is really no drawback to that however as long as you know you are not getting what you ask for---the only way to make sure what you are ending uo with is to loog the AFR's with a wideband 02 sensor---that is the tell all final word on what the ACTUAL AFR really is.....
PS: to correct the VE table is a time consming affair and takes hours of street driving with the MAF disconnected logging and pasting PT fuel trims up to 4000 rpm's in every cell---then after you have the PT coreected you have to do the same with the WOT wide band AFR's and correct it there with either the IFR table or the MAF tabl
The only other thing that might be happening is that your computer is going in the "cat overtemp protection " mode intermitently and what that does is richen up the AFR for a while to cool the cat off and that AFR is in he 11's--look at that table to see if it is exactly 11.3--if it is then that's whats happeninig--have him disable it and it won't happen again----
Old 02-25-2007, 04:14 PM   #5
LuvmyC5
CF Senior Member
LuvmyC5's Avatar
I still have cats on the car and want to ask the tuner if he turned COT off. Another thing is to check OLFA to see what it's set at. If either of these are off, then WOT fueling would be off. I'll just have to wait and see.
I don't have the tune in front of me (he was suppose to send it to me Friday but didn't, so I've got nothing to look at. Which doesn't matter because I couldn't read it anyway bwecause I've got EfiLive and he uses HP Tuners).
Old 02-25-2007, 07:17 PM   #6
tblu92
CF Senior Member
tblu92's Avatar
what is OLFA ?? not a term I'm familiar with
Old 02-25-2007, 08:11 PM   #7
CorvetteTechInc
CF Senior Member
CorvetteTechInc's Avatar
Open Loop Fuel/Air.
__________________
Specializing in Corvette and Muscle Car Performance & Tuning, Restoration, & Mechanical Repairs.
You want Specials! Call us!
Servicing the Mid-Hudson Valley and Surrounding Area.
Installer and Tuner for all popular SC, TT, N2O, Heads and Cam Packages, and more.
Want your Vette Overhauled, call us!
845-542-8930
Home of The FrankenSport Resto-Rod and Custom Built Corvettes!
CorvetteTechInc is offline   Reply With Quote
Reload this Page Strange tuning question for you guys.......................
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
