Corvette Forum
Go Back   Corvette Forum > C5 Corvettes, 1997 - 2004 > C5 Scan & Tune
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
C5 Scan & Tune
Corvette Onboard Diagnostics, Service Advice, Dyno Tuning, Fuel Management, Tuning Software, LS1 Edit, AutoTap, Diablo
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 02-22-2007, 09:10 AM   #1
TopCat
CF Senior Member
TopCat's Avatar
Default LG Headers - Xtra Bung Location... I've searched
I've searched and only found one picture showing someone's installation of an extra bung for a wideband and an EGT sensor.
I'm getting ready to install some LG streets and want to get the bung welded in before the install..... anyone have pics showing where they put their's? I'd like to have it between 10 and 2, but want to be able to remove it when done tuning. Not sure if I can put it in the 1 to 2 o'clock position on the passenger side collector without having the sensor hit the underneath of the car, and I don't think it would be a good idea to stack it behind the bung that's provided for the narrow band stock sensor in the 10 o'clock position....
Any advice would be very much appreciated!
TopCat
TopCat is offline   Reply With Quote
Old 02-22-2007, 05:50 PM   #2
tblu92
CF Senior Member
tblu92's Avatar
I couldn't find a place to put mine safely between 10 and 2 o'clock--So I ended up at about 8:00 on the drivers side--not perfect but if you only use it for tuning and plug it after use then it will be fine--Mine works perfect--The reason for the higher mounting is to prevent water or moisture from settling into the sensor after shutdown and during warm-up---but if you remove it after use--its OK----
tblu92 is offline   Reply With Quote
Old 02-22-2007, 06:20 PM   #3
Billf6531
CF Senior Member
Billf6531's Avatar
You can always replace the stock n/b with the w/b for tuning, and then swap them back to stock when you're done. No need for a bung on a temporary application.
__________________
Best regards,
Bill
Calgary, Alberta, Canada
2003 Quicksilver roadster , 1SB, F55, QF5, MN6, Z06 Ti catback, 2 cat H-pipe & air lid, Euro red/amber tails, Vette Net, and HP Tuners s/w - available for free to anyone in Calgary
Billf6531 is offline   Reply With Quote
Old 02-24-2007, 12:12 AM   #4
TopCat
CF Senior Member
TopCat's Avatar
Quote:
You mean wire it up to act as a NB for the PCM and also connect to the WB controller for tuning? That's a great idea
Now why didn't I think of that?
Silly... I thought about doing it permanently, but didn't want to burn out the WB by leaving it in.... sometimes the old gray matter doesn't work well.
Preciate the info!!!
Old 02-24-2007, 07:18 PM   #5
cjs27410
Southern Hotboater
Support Corvetteforum!
cjs27410's Avatar
I put mine in the x-pipe.
cjs27410 is offline   Reply With Quote
Old 02-28-2007, 12:22 AM   #6
TopCat
CF Senior Member
TopCat's Avatar
Default I would too, but....
Quote:
The x-pipe on the streets is way back and doesn't leave much room for it. It's a Magnaflow unit. I'm sure I could get one in there, but it's waaaay back. I think I'm going to go without cats and see if I can stand the vapors, so I may just use one of the rear O2 bungs. Then if I have to put the cats back in, we'll just see what the A/F's come out at. I want to see how mean this thing sounds with the LT headers and Borla stingers... should wake the neighbors on Sat. mornings
Old 03-02-2007, 11:53 PM   #7
muncie21
CF Senior Member
muncie21's Avatar
Put mine after the x-pipe. No cats here though.
muncie21 is offline   Reply With Quote
Old 03-03-2007, 10:48 PM   #8
'VETTE PHASE
CF Senior Member
Cruise-In VIII Veteran
'VETTE PHASE's Avatar
Searching around on the 'net, I found that some manufacturers prefer that it stays in the pipe and in use all the time and that it should last for 100,000 miles this way. I use mine as a narrowband, so we'll see.
__________________
2005 Z51 Convertible MN6
- forged 404 c.i. LS2
- D1SC @ 13.5 psi
- Flip Drive
- 243
.624 on a 114 lsa
- 1 7/8" Kooks SS headers w/ 3" X-pipe, Corsa
- 707 rwhp
- Meth injection
- rear Widebody conversion
'VETTE PHASE is offline   Reply With Quote
Reload this Page LG Headers - Xtra Bung Location... I've searched
Tags
bungs, corvette, headers, lg, rear
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
